    Results 1 to 9 of 9
      Jun 2010
      Deployed
      SD5 or SD7 compressor?
      Not sure which to go, compact size of the SD7 or the better performing SD508. What are you all using with LS Swaps?
      1970 Camaro/DSE build
      Apr 2013
      I have the SD 508, reason being is that it can handle higher RPM's than the SD-7. Mine is a Vintage Air installation in a 69 Firebird w/ a stock LS1 GTO engine.
      Tim john---
      Jun 2010
      Deployed
      Quote Originally Posted by Tim john--- View Post
      Tim john---
      Is is it mounted high with a conversion bracket? Do you have pictures?
      Ehats the the rpm difference?
      Mar 2015
      I've got a 63 chevy II wagon so different cars but still check out reply #6. He works for VA and was very helpful to me on my project. https://www.pro-touring.com/threads/...ure-Fit-gen-IV
      Jun 2010
      Deployed
      Well good post, but just talked in circles....what are you all using and are you happy?
      Metamora, Illinois
      I'm using an SD7 mounted up top with a Holley a/c bracket. It works great for the intended use, which is mainly daily driver type use. Personally I don't think you can go wrong with either......just try not to overthink it as both have been used with great results.
      Jun 2010
      Deployed
      Any other inputs? I'm also thinking about size and room for it. How small is the sd7?
      Mountain Springs, Texas
      Use the bigger SD508 if you have room. You won't regret it living in the desert...
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Sep 2013
      Hood River, OR
      Here are the dimensions of the 508 and sd7:
      http://www.vintageair.com/catalog11/pg88wc.pdf
