      Sep 2015
      Beaumont, Tx
      2nd Gen Fbody Transaxle Install
      Thinking about installing a corvette transaxle in my 73 Camaro. Anyone here have any information on the pros and cons of this idea? Obviously it would be done to create better weight distribution which leads to better performance. Could it also make way to set up a corvette independent rear suspension as well? I would appreciate thorough explanations. I want to build this car a little different from the pro touring crowd.
      Central CA USA
      I was looking at it before finding the Morrison IRS.
      More rear weight bias is attractive. My concerns were, strength and durability of the components at higher HP levels, more difficult to change a clutch, the whole trans, tube, and rear suspension has to be dropped down as one. Concerns over shortening the driveshaft tube & shifter rod, strength of the driveshaft couplers front & rear. How to route the exhaust around the transaxle & suspension. The suspension is pretty wide hub to hub, so you need to figure out if you will go widebody / putting fender flares on, run deeper backspace wheels, or shorten the rear A arms / build your own. lots of work to the frame rails, floor and perhaps the trunk floor. You might get by without modifying the gas tank.
      Sep 2015
      Beaumont, Tx
      What would you consider higher HP levels? 550-600 HP N/A too much? The exhaust looks to route side by side down the torque tube, so is it the axle backs that you're mainly concerned about when routing the exhaust? Would having the exhaust exit on the sides in front of the wheel well solve this problem? For so, it might add to the cool factor. Due to torque tube and shifter rod having to be modified, does this also cause concern for making the transmission tunnel bigger all the way down to rear of the car? With mini tubs already installed in the car, would mounting points have to adjusted and then cause for a wider body anyways? I was debating on installing fender flares anyways. What kind of work to the frame rails did you think needed to be done? The frame rails in the back of my car are going to have to be replaced anyways. There currently isn't a trunk floor pan either, would this cause the trunk floor pan to be raised for more clearance? Also, with so much going on in the rear of the car, would the back seat frame need to be adjusted and leave no room for a back seat? This also being a concern with the transmission tunnel having to be bigger?
      Sep 2007
      It's a great idea from a weight balance POV.
      But everything about an IRS/transaxle Corvette is so different.
      I suspect that by the time you got the whole project done, it would either be:
      A) - you mounted the entire rear half of the modern Corvette chassis underneath your old car in a big lump, or
      B) - your custom-built end result came out so similar to that, that you wish you had just done a big lump swap in hindsight.
      Sep 2015
      Beaumont, Tx
      I have looked into just taking a whole corvette rolling chassis and the retro fitting the camaro to it. However, I believe I would be looking into so much fabrication. I guess the real question would be, is it worth it? From a performance and drive ability aspect. I'm still curious to know more information about the steps needed to make it work. Mr. Pozzi up top made some points that I wouldn't have thought of until I actually started getting my hands dirty. The car needs a lot of work regardless. So maybe the best time to do it is when the car has to be rebuilt? I've always wanted to do something different and maybe a little innovative. Just didn't know if it was possible to do without necessarily going bankrupt.
      St George Utah
      check with Rodger at Ironworks he has done a few cars with that set up and I Think it is about a whole new chassis from the firewall back to make it fit.
      Blake Foster
      www.speedtechperformance.com
      435-628-4300
      St. George Utah.
      it's always sunny here.
      Sep 2015
      Beaumont, Tx
      Is that Ironworks Speed and Kustom?
