- Mar 2016
- 84
1969 camaro engine stand questions
although it may not be correct, can't you technically bolt a big block to small block frame stands and a small block to big frame stands?
i'm working my way through a 2nd hand project. the previous owner had short/wide mounts bolted to a 1969 narrow frame mount. I decided to put the correct tall narrow solid motor mounts in. the passenger side bolt slipped through like butter. the driver's side is about 1/2" off.
that's when I realized the car has 1969 big block frame stands....but technically, shouldn't a small block still line up and bolt down using those stands? I know it could possibly create driveline issues, but having the extra height on the driver's side would help in my case.
