    Results 1 to 9 of 9
      Mar 2015
      Ride tech Level 1 work with chevy 10 bolt?
      Might be a dumb question, However I was curious if the Ride tech level one kit will work on a chevy 10 bolt?. I have read on the Speedtech forum that their Camaro GT suspension kit will work with "12 Bolt". Just curious if that would include a 10 bolt. Thanks for looking.
      Ray
      Mar 2015
      I just saw on speed techs tq arm kit it gives the option for a 10 bolt.
      Dec 2008
      Detroit
      The 10 and 12 bolt housings are dimensional the same. The only reason why they need different versions is because of how the torque arm bolts to the rear and the bolt spacing. This is why they have to have a 12 bolt, 10 bolt, and Ford 9"version.
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      Mar 2015
      The 48 Hr camaro vid on youtube mentions that if you had a 10 bolt you "should" sell and get a 12 or 9 bolt. This true? Can I not use my 10 bolt. I am referring to using Ride techs 4 link.
      Aug 2003
      Wanatah, Indiana
      I have the ride tech 4 link bolted to a 8.5 10 bolt. I think they are referring to the 8.2 10 bolt which is a weaker rear end. If you have any kind of hp you probably should upgrade at that time if you have the 8.2.
      Feb 2013
      There aren't any issues with the 10 bolt fitting in the car, the brackets are all the same as well.
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
      Mar 2015
      Thanks for the Reply Mark & Josh
      Oct 2010
      Sacramento, CA
      Not all 8.5 10 bolts are the same, the early Nova is different from the 2nd generation Camaro rear.
      Rick - 1969 Camaro - LS1 driven daily
      bowling green,ky
      i have beat the snot out of my 8.5 10bolt for 15yrs. nothing wrong with them at all
      69 Camaro
      03 z06
      90 mustang coupe
