      Jun 2014
      Powder coating lower control arms with ball joints
      I want to re powder coat my Griggs lower control arms on my 94 Mustang. The ball joints are installed but I am replacing my rubber dust boots. Can I powder coat these without removing the ball joints?
      May 2016
      Bay Area
      Quote Originally Posted by BlackMachOne View Post
      I don't think so. Every time I've powder coated A-Arms I had to remove the ball joints. Something about getting sand in there will leave them ruined. big pain in the butt. You may want to tape them off and spray paint them instead.
      Feb 2013
      I would pull them out just to be safe.
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
      Lowell, MI
      No, take them out.
      Turbo Charged LS1/T56
      Aug 2010
      Seattle area
      I would also pull them .The high heat won`t do them any good.
      No you can't PC with them installed - between the Powder & the Heat, you would ruin the Ball Joints
      Jun 2014
      Thanks for the advice. I figured it wasn't a good idea. Hopefully I can have them removed and re-installed without damaging them.
      Southern Indiana
      Stock style join ts should come out easy, Oreillys usually have ball joint / ujoint tool to rent/use
      Lee Abel
      AFTERMARKET PERFORMANCE
