Results 1 to 16 of 16
Thread: Kore3 C6 Z06 clearance
06-15-2016 #1
Hi all...was going to use E/T wheels LTIII on my car but the backspace I need up front won't clear these brakes. I'm needing an 18x8 with 5.5 backspace.
Anyone here eres with those brakes? What wheels did you use?
Manuel Scettri
1973 Firebird - Pontiac 455
1990 2 Door 4Runner - byebye
2016 KIA Sportage diesel - The Daily Driver
06-15-2016 #2
- Jul 2005
- Houston
- 93
I have these brakes on an iforged seneca wheel. 18x9.5. Kore3 will send you a drawing of the brakes and you should send that to the wheel mfg. The key is to make sure the wheel hub is deep enough for the brakes to fit. The Z06 brakes calipers are large, to make it fit on an 8" wheel you have to move the spokes towards the front of the wheel which in turn eliminates the lip in the front.
Here is a sketch of what I'm talking about. (its 5.75" BS but you can do the math to see how much lip you have left in the front)
06-15-2016 #3
- Jul 2005
- Houston
- 93
here is the fitment guide from kore 3 - as you can see, your hub needs to be at least 1.75" deep to clear your wheel spokes. http://www.kore3.com/downloads/fitme...es/DOC0019.pdf
06-15-2016 #4Thanks for that wheel suggestion, and the template.
I actually already have all the things needed...just need to find a wheel that has a thick enough pad or spokes that have enough curve to clear the brakes. Might just make my own...Manuel Scettri
06-15-2016 #5
