    Results 21 to 40 of 58
    Thread: Life sucks...
      Hildebran, NC
      I redid my math from above.
      By chance you think you could go back and find the yoke? Might be the smoking gun...
      Aug 2010
      New Albany IN.
Size:  476.8 KBName:  20160517_143718.jpg
Size:  264.5 KBName:  20160516_185248.jpg
Size:  476.8 KBName:  20160516_185248.jpg
      Car was starting to look mean 😔
      May 2015
      Quote Originally Posted by corvettekid1973 View Post
      I like the rear wheel offset.
      What width is your rear axle?
      Stock width?
      Car looks great!
      Thx
      Aug 2010
      New Albany IN.
      Probably not... i coasted a while till I could get over
      Dec 2010
      Fredericksburg, VA.
      WOW, that's a lot of carnage. I'd be willing to bet that the combination of the 4.11 and the 80mph were just too much for the slip yoke. Was that transmission a Magnum? Damn good thing you had a driveshaft loop installed.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Aug 2010
      New Albany IN.
      Good lord, that's a lot of carnage. I'd be willing to bet that the combination of the 4.11 and the 80mph were just too much for the slip yoke. Was that transmission a Magnum?
      It was a regular t56 from a 1998 trans am. I found a rebuildable core for $200 and $100 shipping
      May 2010
      kitchener,Ontario,Canada
      The car still does look mean ....just doesn't go mean right now ...get that Trans and eventually a sfi bellhousing ,be good to go
      Ryan Austin
      On Instagram ryanaustinss70
      Aug 2010
      New Albany IN.
      That's the game plan ��
      Jonesboro, Arkansas
      And I'd get rid of those 4:11 gears on the highway. What RPM were you turning at that speed? I have 3:73's behind my 6 speed and at 70 MPH in fourth I was turning 3200 RPM.
      Carl Wilson
      Aug 2010
      New Albany IN.
      Quote Originally Posted by minendrews68 View Post
      Huh? 411's with a 6sp is great I was turning 2k at 80 mph in 6th. Why where you using 4th on the highway with a 6sp?
      Jonesboro, Arkansas
      Didn't mean to start anything. I wasn't running in 4th on the highway, I'm just saying that in 4th I was turning around 3200 rpm. I was just meaning there are a lot of good that comes from running a higher gear than the 4:11 gears. As stated above, and when you lower the rpm's you will also take away more strain on the drive train on the highway. It's your car and you can certainly run whatever gear pleases you. We're only offering suggestions.
      Carl Wilson
      May 2010
      without knowing tire size....3.73 is probably the better choice
      Ryan Austin
      Aug 2010
      New Albany IN.
      I have a rebuildable core coming so the healing process will slowly begin
      Dec 2010
      Fredericksburg, VA.
      I would tend to agree that the 4.11 is a bit too low. I'm running a 3.89 and have been very pleased with it.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      Aug 2010
      New Albany IN.
      Im happy as can be with 411's. I have a little 5.3 with a hot cam and it moves really good and turns under 2k rpm at 65
      May 2010
      You seem to be missing the point .....lower numerically gears will help a few things ....
      1 fuel economy
      2 lower drives after speed
      3 higher top speed
      Ryan Austin
      Aug 2010
      New Albany IN.
      Look up some of the big name people like Detroit speed and see what kinda gearing they run.
      Mar 2015
      Anaheim, Ca
      Were you on it hard when it came apart?
      I always always always run a good quality rubber trans mount reguardless of what motor mounts I'm using (solid/ poly ect). I've see a few trans cases busted because the engine torques and moves, and the trans stays where it is and twists and busts the case. I don't know if that's what happened here but it's a thought, especially if the rest of the internals on the trans are good.
      I'd also check for a busted motor mount.
      PS my car has a 9" with 5.14 gears and a .55 OD :D
      JORDAN
      Jun 2010
      Deployed
      3.89s, 3.90s, and I'm sure Finch uses 4.1x.
      1970 Camaro/DSE build
      Aug 2010
      New Albany IN.
      Yeah and I am fine with my fuel economy. And im not going to the salt flats. And my little 5.3 with the cam loves a little RPM. A lot of people don't match their cam and gears. My tuner is one of the best in the nation and has building 1000 hp LS cars before people even had a clue about them. He is even in GM's book along with Ed Wright
