    Results 1 to 9 of 9
      Las Vegas, NV
      Off Road, LS Engine, Too Many Parts!
      Clearing out shop after move and various car builds
      Some members may be into multiple motorsports like I am and will know the offroad parts as well
      Prices do NOT include shipping from Las Vegas, NV 89131
      Will post all pics soon (alot of them!), or pm/ text for pics
      Off Road Parts:
      -Cables:
      - 1 pair of #4 push/ pull control shifter cables used, 2" throw/ travel, 55" overall, 42.5" bulkhead to bulkhead centers $80 pair
      - 1 #4 push/ pull control shifter cable , new, 1" throw/ travel, 79" overall, 69.5" bulkhead to bulkhead centers, from Kartek $60
      - 1 #3 push / pull throttle cable , new 3" throw/ travel, 140" overall, 126.5" clip to clip, from Kartek $40
      - 1 #3 push/ pull throttle cable, new, 3" throw/ travel, 156" overall, 142.5" clip to clip, from Kartek $40
      - 1 PBS/ Mendeola S4 shifter, new, from PBS $60 SOLD!
      - 1 pair of CNC Turning/ Steering brake handle knobs Blue, new (just mock up, changed color) $20pr.
      - 1 Tilton oil / gear cooler pump w/ wiring, relay, used, cracked fan cover (#40-910 $12 to replace) $125 SOLD!
      - 1 Allstar Performance billet oil filter / ?? mount , new (#92046) $20
      - 1 Tru-Cool/ LONG oil cooler with #10 an stainless braided hoses and fittings, used, (cooler is 11 x 11 x 1.5", hoses are 34" w/ 90 degree fittings, 38" w/ 45 degree fittings $75 SOLD!
      - 1 Aeromotive billet fuel filter mount, new $50
      Hoses & Fragola Fittings:
      - 1 #8 power steering hose, new, 53.5" overall w/ fittings installed (1-90, 1-straight) $30
      - 1 #10 power steering hose, used, 39.25" overall w/ fittings installed, (2-45 degree ends, clocked close to opposite each other) $30
      - 1 #8 x 120 degree Push Lock black (2125008-BL not in bag) $15
      - 1 #8 x 90 degree push lock black (#209008-BL) $15 ea
      - 1 #8 nut x #6 male swivel reducer black (#497208-BL) $6
      - 2 #8 female connectors black (#496108-BL) $6 ea
      Drivetrain:
      - 1 pair of Pro Am 934 Double Boot flanges (trans side w/ 1/2" holes)w/ outter boots & o-rings, need inner boots, mocked up $100 pair SOLD!!
      - 1 934 33 spline 300m axle, low use, 34.5" overall, (one end trimmed down 3" spline & 4" spline lengths) $300
      Springs/ parts:
      - 1 pair of King coil springs for 2.0" c/o shocks (#2.5-12.00-400) new $100pr
      - 1 pair of King coil springs for 2.0" c/o shocks (#2.5-12.00-500) used half season $60pr
      - 1 pair of King lower spring retaining plates (flat) for 2.0" c/o shocks new $40pr
      Rod ends & threaded bungs;
      - 2 5/8"-18 Hex RH bungs for 1" tube, (don't recall for which tube size, bung is .748" od @ tube insert end) new $15pr SOLD!
      - 2 5/8"-18 Smooth RH bungs for 1" tube (don't recall for which tube size, bung is .807 od @tube insert end) new $15pr SOLD!
      - 4 5/8"-18 RH & LH (2 of ea) Chromoly rod ends w/ 1/2" hole $20 ea SOLD!!
      - 4 1/2"-20 RH & LH (2 of ea) Chromoly rod ends w/ 1/2" hole w/ smooth end threaded bungs for .065" wall 1" tube and jam nuts $30 ea SOLD!!
      LS / Vortec engine parts:
      - 1 SPEC steel flywheel, light use $150
      - 1 pair of RSI Billet Fuel Rails, black (bought for stock LS3 manifold, but not correct size) (see pics for dims) with new fittings also, used SS crossover I had $140 SOLD!
      - 1 BTR (Brian Tooley Racing Stage 4 n/a cam (233/250, 619/595 113+5 LSA , 3 bolt) used 2500 miles $300
      - 1 Comp Cams cam w/ XE-R lobes (224/236, 581/602 113 LSA ,3 bolt) used low miles $300
      - 1 GM stock LS3 cam (#3063 ,single bolt) low mileage take out $50
      - 1 GM stock LS2/ LS3/ LS7 fuel rail (#12638197, new take off) $80
      - 1 3 bolt throttle body to 4 bolt throttle body billet adapter w/ o-ring, used $40 SOLD!!
      - 1 set of MSD spark plug wires for LS1/2/3/6/7 , low use $30 SOLD!
      - 1 set of GM stock take off LS3 spark plug wires , low miles $20 SOLD!!
      - 1 GM LS3 LS7 card style MAF Sensor with 4" dia alum tube and welded bung, tube length is 4", used $120
      - 1 Stainless steel 4" dia " Y air intake tube", has slight bend ,(see pic) 14" overall, 5 1/2" tall, used $80 SOLD!!
      - variety of lengths of 4" dia. aluminum intake tubing & rubber couplers (2@ 5 1/2", 2@ 4 7/8", 1 2 5/8" w/ 9/16" hole, 1@ 12") couplers are 2 3/4" & 3", used, Offers ? SOLD!!
      - 1 Throttle cable adapter (Morse style cable to cable throttle body DBC) 10 1/4" long, used $10 SOLD!
      - 1 pair of GM LS3 rocker stands ( 1 pair used) #12600936 $10 -used pr
      - 1 pair of GM LS1/ Vortec rocker stands, used $10
      - 1 GM "LS6" oil pump,(#12556436) new, bolted to engine, then removed, never run $70
      - 1 GM Gen III knock sensor harness, used, $15
      - multiple sets of 5 GM/ aftermarket LS1 / LS6 Fuel Rail Cover mounting studs $50/ set of 5
      - 1 set of 16 Texas Speed #25-7450 7.450" .080 wall Pushrod set, new in box $90
      Other:
      - 1 pair of Rigid Industries Dually LED lights, Amber & flood pattern, new, but mocked up and chassis sat out in sun, black is faded a bit w/ connectors/ plugs $100 SOLD!
      - 2 SPAL 14" Electric fans, curved blade, new, but mocked up and chassis sat out in sun, fan "grilles" have a few missing ribs, never used $75 ea SOLD!
      - 1 pair of weld in seat mounting brackets, 18" center to center spacing, new $40pr SOLD!
      please pm/ call/ text (702)677-4085
      [COLOR=#000000]Thanks, Jeff[/COLOR
      Las Vegas, NV
      additional pics
      Jun 2010
      Deployed
      Jeff why wouldn't the billet rails work on the ls3?
      1970 Camaro/DSE build
      Las Vegas, NV
      The front to rear spacing was correct, but not the side to side (with the mounting brackets that I got with them) needed to be "pushed out" from intake manifold
      I will post pics on the dimensions
      Las Vegas, NV
      list updated
      Las Vegas, NV
      weekend bump
      Las Vegas, NV
      Holiday bump!
      Las Vegas, NV
      List updated
      Las Vegas, NV
      updated list
