    View Poll Results: What would you be willing to do to install a full-frame chassis?
    Voters
    58. You may not vote on this poll
    • Anything! Cut the floor, trunk, and possibly areas of the firewall.
      26 44.83%
    • I'll fab a trunk or a a portion of the firewall, but I won't cut the floor out.
      4 6.90%
    • I don't mind fabbing a new floor, but I wont touch the trunk or firewall.
      5 8.62%
    • I would only cut the floor if I had a pre-made floor pan to weld back in.
      23 39.66%
    Multiple Choice Poll.
    Page 3 of 3 FirstFirst 1 2 3
    Results 41 to 54 of 54
    1. #41
      north central Iowa
      i think the video idea is a pretty good one, it will allow the potential customer to put a visual on what they would actually be performing, so it wouldn't seem too overwhelming. It's like when i tell people of my plans to use a max-g chassis and that the whole floor would have to be removed etc... you should see the look on their faces and the coment "you're going to do what?!!!!"
    2. #42
      Jul 2007
      Humm. My thoughts of the the Max G chassis for unibodies are:
      If the 2"X4" square tubing used for the chassis rails are on end (4" tall) the only way to hide the chassis is to channel the body. Now the next question rises, does the floor have to be raised 3"-4". If so, how much room is left for us taller guys? I measured 37" from floor board to the bottom side of the roof. And thats with out a headliner. Next, if the body is channeled over the frame, that leaves even less room for a big block. Has anyone run a Max G chassis under a GM unibody car yet?
      1970 Camaro
    3. #43
      Feb 2006
      SoCal
      I was interested in your companies Max G frame but since it didn't support an IRS and I could only use the Morrison front end rather than the C5/C6 I wanted to use, I opted to have it custom made!
      Do you guys have any plans on doing a frame for an X-body/Chevy II? I remember talking to Craig in PM and him telling me that they were almost done with the R & D for the 2! Are you any closer? Lotsa Deuce owners out there that would like this option now that JP's car is terrorizing the track!
      John
      ***Under Construction***
      Build Update Link:
    4. #44
      Greenwood, SC
      New member here.... I'm not the most knowledgeable about what is the best design for specific applications, but most professionally built race chasis are mandrel bent tube chasis. Why not try to design a full bolt-in mandrel bent tube chasis that will be much lower profile than boxed frame rails. Im not sure of the cost difference between these two styles, but if you convinced me that a tube chasis was better than full frame chasis for a touring car, then I would most deffinatley be more inclined to buy the tube chasis. The idea of including the floorpans sounds great, but maybe if you are going to be replacing floorpans, then why don't ya'll design and test some floor pans that will give better aerodynamics on the whole underbody of the car. Or perhaps build the floorpans (and tranny hump) to recieve the framerails and recess them like a body drop giving you a lower COG. Just a few ideas. Might be worth looking into. Also, I (being one of the many shadetree mechanics) love the idea of an installation video using the simple and more common tools. Good luck with everything.
    5. #45
      Illinois
      Nova G-Max Frame
      I talked to Morrison last month about a G-Max for my 67 Chevy II and they said that they have been available for a while now. As it turned out theres one in my town, haven't had a chance to check it out yet.
    6. #46
      Feb 2006
      SoCal
      Quote Originally Posted by farmer13
      With Vette suspension and IRS? When I spoke with Kevin Kosier I was told that they only offer the Max-G with AM spindles and CA's. Kevin also told me that to try and sort out the IRS was too time consuming and the triangulated 4 link they had performed as well if not better than the 'vette IRS. Has this changed? Do they now offer it with 'vette arms, spindle, hub and IRS?
      John
      Build Update Link:
    7. #47
      Auburn, WA
      Quote Originally Posted by novanutcase
      John
      John, we can indeed to a full frame for a Chevy IIs with a C6 setup...the problem is track width. The Chev II requires a hub track width that is narrower than we are able (read: want) to build.
      Sooo...we could do it. But we want to make sure you'd be happy with the product...and if you're OK with some goofy offset wheels (remember the front-drive Toronado wheels?), then it is not a problem.
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
    8. #48
      VA
      Does anyone have any pics of a max g under a 68 or 69 camaro? I'm curious as to what needs to be cut to make it fit right?
      I have a 68 that needs re paneling, I've considered doing a full chassis but it all depends on how it fits.
      What are the chances of having a full chassis catch the front 2 mounting points and continue from there? You'd have to cut like you would with connectors, but say we remove the rear frame rails, can something be made to go in place of the stockers? We'd have to create a place on the existing panels to mount the body to in the back.
    9. #49
      Feb 2006
      SoCal
      Quote Originally Posted by silver69camaro
      The track width on the front end of the custom chassis I had built for the car is 54 1/2" using C5/C6 lower arms. We actually lengthened the uppers with some tubular arms we made . I'm running a 6 1/2" backspace on a 9 1/2" front wheel and we have been able to get lock to lock with about a 1/2" clearance to the fenders.
      I really like the Max-G but since you guys didn't/don't(?) support any IRS installations then/now(?), I wanted to utilize the 'vette IRS transaxle for the weight distribution properties it presented!
      Check out the build link in the sig below! Tell me what you think!
      John
      Build Update Link:
    10. #50
      Auburn, WA
      The narrowest C6 IFS we make is 57-1/2" hub track...which is where the problem starts. Like you said, 54" is what is usually needed. The problem lies with the rack and pinion...I've never found a modestly priced rack that will work for us. Sure, we could use a nice Sweet or Woodward rack, but 96% of our customers will not want to pay for the major additional expense. Otherwise, I'd be all over it in a heartbeat.
      As far as the IRS goes, we "passively" support it. If the customer states that he/she wants to run a C5/6 IRS, we simply design the rear rails to their needs...and they install the IRS. It's hard to justify supporting the IRS in-house due to its cost, complexity (read: inflexibility to run with various frame widths), and quite frankly...our 3-link and triangulated 4-bar works damn well for much less dough. They're proven designs that have beat out IRS-equipped cars in previous competitions.
      I've been following your build for quite a while now. Simply put, it rocks.
      Matt Jones
      Mechanical Engineer
    11. #51
      Feb 2006
      SoCal
      AHA!!!! So the issue comes down to the R & P not fitting the chassis? You would think that someone that is going to all the trouble of putting an entirely new chassis on their car would be that worried about running a woodward or sweet rack! Yes they aren't cheap but either is a full chassis! Interesting!
      I can understand the IRS issue. It is not easy to dial in but when you can it really straddles both performance and comfort nicely!
      John
      Build Update Link:
    12. #52
      Auburn, WA
      John
      Yes, that's what I would think too. I know a few people who would do it (guys like yourself, etc) who have some pretty wild builds.
      One way to think about it is the customer has the option of a very trick C6 IFS w/ a Woodward R&P, or our in-house IFS setup. With the fancy rack, I bet the price would double over the Morrison IFS. Many people wouldn't see that as worthwhile. I'd love to do it though.
      Matt Jones
      Mechanical Engineer
    13. #53
      Tacoma, Washigton
      Full frame for unibodys
      I would love a full frame for my 1978 28 Camaro with C/6 brakes which will fit 18x10 and 285 or 295 35"s up front with room for the biggest Mickey Thompson's Street Radials up to 22 inch wide I could stuff up under and still hang corners with the best of them. Well maybe 18 wide but 20x16 wheels would be killer, personally I like the idea of something that I could work with a little sheet metal work no problem, keep those ideas rollin, Claude.
    14. #54
      Auburn, WA
      Quote Originally Posted by 1bluaddict
      And have it be all wheel drive, right?
      Matt Jones
      Mechanical Engineer
