      Fond Du Lac,Wisconsin
      LS Header Gaskets
      I need a set of Header gaskets of a LS-7 for a set of Stainless Hooker headers 1 7/8 Primary tube. Whats good out their , Earl's Pressure Master seals other brands , Copper , Aluminum ?
      Apr 2012
      Woodstock, IL
      LS Header Gaskets
      We always have good luck with the GM ones.
      -Dale
      SchwartzPerformance
      Mar 2013
      There's nothing that works better than the stock GM gaskets on headers with flat finished flanges that are 3/8" thick or more. For older design headers that use raised/ground weld beads around the ports it's a different story.
      Dec 2015
      Never used anything but a GM gasket on several LS engine builds. Even had performance shops tell me to throw away the ones that come with aftermarket headers if they are not the GM versions.
      went with the GM gaskets Thanks
