    Page 6 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
    Results 101 to 120 of 136
    Thread: Carbon Fiber
      May 2016
      Yes but you still want crush zones .... otherwise it's a human which must absorb the impact energy, race cars somewhat combat this with race seats, harnesses and Hans devices ...
      Crush zones are not good in old cars anyway. Advancements in steel that makes it possible for the safety of modern cars didn't come about till almost 2000. Older Corvettes don't have crush zones either and I don't hear people complaining about it. I think you are making a much bigger deal out of it than it really is.
      Personally, I'd rather have my cockpit not crush me vs the minor amount of absorption it will take before smashing me inside the car...
      https://youtu.be/joMK1WZjP7g
      May 2016
      There are modern cars with a carbon fiber monocoque. The Lamborghini Aventador is one as well as the Koenigsegg and many others.
      May 2010
      kitchener,Ontario,Canada
      are you on glue ...? how the hell do you think new cars are built ...im a fabricator and do TONS of work for toyota canada .....crush zones are built into every car starting at the front bumper , go look at some info about the newer F150's , the lambo still has crush zones...again starting at the front end and stopping before the interior cabin . do a google search of crush zones ,crumple zones etc . you are clearly missing the point and or info. advancements in metal technology is crazy , even if there isnt a crumple zone in the literal sense of what we all think auto manufactures will add softer metal in certain areas to absorb the energy created by the impact
      Ryan Austin
      On Instagram ryanaustinss70
      May 2016
      Where did I say newer vehicles don't have crumple zones? Where did I say the Lambo didn't? Old cars might have had some built into them but they were nowhere near as effective as newer vehicles, especially after 2000 where they were able to make significant advancements in metal strength. I think you are missing my point. My point is that old cars, classic cars, don't have near the safety as a newer vehicle in the sense of crumple zones. I linked the video that showed just that. The newer vehicle cockpit stayed mostly in tact while the classic car cockpit was crushed. My point was that I would rather not be crushed in my cockpit like the old cars tend to do. Where am I wrong here?
      May 2010
      Your wrong in the aspect that you want to take a car that admittedly sucks in crashes and want to make it worse by making it stronger .....you would Want to add crush zones so that the car would react much like a new car ....and the chirps about new cars is a reference to the 2000 and up model yrs .....crush zones have been designed into cars way before then ...and I certainly don't see why that's the year you think changed everything
      Ryan Austin
      May 2016
      How are we supposed to design crumple zones when we're only designing the unibody and not the firewall forward where the largest majority of that would be placed anyway? You are wrong in thinking by making it stronger will make it worse. Sure you might take a little more shock to your body but your body won't get crushed by the collapsing cockpit. I'd take some whip lash over a crushed torso any day of the week and twice on Sunday.
      Look, we will design as much safety into the car as we possibly can, but if someone is looking for modern safety then you really have no business looking at a classic car. If you want modern safety then buy a new car.
      It changed around the early 2000's because they added about 1/3 more strength into the stamping process of metal.
      It Starts With the Steel
      Considering all of the rapid developments we've seen with electronic safety systems in recent years, it's perhaps counter intuitive that some of the biggest safety improvements in the past decade have come from good old-fashioned steel. "Over the past 10 to 15 years, steels have been getting stronger," says Chuck Thomas, chief engineer at Honda R&D Americas, in Raymond, Ohio. "We probably had 500 megapascals of tensile strength in the early 2000s. Now hot-pressed or hot-stamped steel is around 1,500 megapascals." At that strength you can hang 200,000 pounds on an inch-wide strip without tearing it in two. The high-strength steel is stamped hot and then quickly cooled, allowing for complex shapes and a wide variability in yield strength, which helps determine how a car deforms in an accident.
      David Leone, executive chief engineer for Cadillac, says that the use of high-strength steel isn't about turning passenger cars into invincible tanks but controlling crash energy and minimizing weight. "Heavy does not mean safe," Leone says. "Heavy means heavy. Go back to the '50s and '60s. The cars were heavy. They were stiff. But if you ran into the wall, you bounced off the wall and all the deceleration went through your body. Heavy and stiff is not where you want to be."
      These advances in steel—along with strategic use of other materials such as aluminum, magnesium, and carbon fiber—allow engineers to design structures that can dissipate and redirect crash forces. For example, the new Cadillac CTS uses lightweight aluminum "crush cans" up front to soak up a lot of energy before an impact reaches the passengers. Even the CTS's seat-belt spools unwind slightly during a crash to help minimize forces on your body.
      The effective mix of stronger materials and crush zones is evident in a slow-motion video of the 2014 Acura MDX undergoing an offset-frontal crash test. As the car slams into the barrier at 40 mph, the front end deforms alarmingly until the shock wave reaches the firewall, where it meets high-strength steel stamped at 1,600 degrees Fahrenheit. Instead of continuing its collapse, the car pivots away from the barrier, absorbing the remaining energy. From the front door forward, the car is annihilated. From the door back, it's completely intact.
      May 2010
      Crush zones can and should be built into the rear section ...i.e trunk
      Ryan Austin
      May 2016
      Well like I said, we will make it as safe as we can with what we have to work with.
      May 2010
      well none of this matters being as im not seening this hitting production....i cant and dont see anyone lining up for a 50,000 body. just trying to be realistic
      Ryan Austin
      May 2016
      I don't totally disagree with you there
      May 2010
      lol ...
      cheers ..guess we will see ...
      i certainly hope you do as it will change the industry ... how would you do it ? buy a new body shell and mold from it ?
      Ryan Austin
      May 2016
      lol ...
      Either that or use the body from my current car I'm building.
      Jul 2015
      I'd start with a perfect, or near perfect car original car, and have it scanned.
      Then a plug, or the molds can be CNC'd.
      May 2016
      Quote Originally Posted by krom View Post
      That would be ideal for sure.
      Dec 2013
      Forged Carbon Fiber:
      http://www.autoblog.com/2016/07/13/l...-carbon-fiber/
      So... who wants to be the first? Seems this tech is the eventual less expensive way to the structural stuff that many want.
      May 2016
      Things are moving along, but slowly. Looks like the first part we may try to produce is a one piece T-Top replacement for C3 corvettes. We will continue to look into the Camaro unibody to get a better idea of actual cost.
      May 2010
      Don't recall who but someone else does make a carbon c3 roof
      Ryan Austin
      May 2016
      That's definitely news to me. If you can find it please share. I've never been able to find it and I've had a lot of people ask for one.
      May 2010
      "Project menace" built by heartland customs . There's pictures our there.... Hell maybe on here , I've seen them
      Edit * page 5 has a picture ,not sure if in the thread it mentions where they got it from but , either way you know who built the car
      Ryan Austin
      May 2016
      From everything I've been able to find, that appears to be a one off piece made for that project. They don't appear to be selling them. Besides, I'm looking at a one piece T-Top right now, not a hardtop.
