    Results 1 to 1 of 1
      Stack gauges and main gauge display
      I have more stuff from my sold C6Z06. I have a Stack ST8130 main display gauge:
      ST8130 Street Display Features
      Stack stepper motor analogue tach display, that integrates the following display parameters:
      • Speed
      • Odometer and trip
      • Oil Pressure
      • Oil Temperature
      • Water Temperature
      • battery Voltage
      • Fuel Level
      • Peak Value Recall
      • User-programmable Intelligent Alarms
      • Separate low fuel indicator lamp
      • Optional Fuel Pressure channel
      • Optional external sequential shift lift
      • Optional Lap Timing and Predicted Lap Timing
      I also have Stack boost and wideband gauges (ST3312 and ST3401).
      All the harnesses, sensors, and connectors are there for the gauges, but I've misplaced the sensors for the main display. I also altered the housing of the main display slightly to fit a tube-frame car I was building at the time.
      See http://www.stackltd.com for complete information about these gauges. This is high-end professional motorsports stuff that I've had for several years, but the project that was to use it never quite came through. These have never been used, but are out of the box and have been fitted. The harnesses are untouched.
      Boost gauge: $150
      Wideband: $200
      Display: $1000
      Package deal: $1200
      Stack boost gauge with MAF sensor and harness
      Stack wideband gauge with wideband sensor and spare with harness.
      Stack main display with harness, instructions, and fabricated steel mount.
      ​John Parsons
