    Results 1 to 10 of 10
      Jan 2000
      Thousand Oaks California
      OBDII - How to hack into it and run multiple devices?
      Does anyone know where a good place is to learn about GM's OBDII port? I'm not even sure that's the correct name for it.
      I would like to leave the connector available for your typical diagnostics but I also have several items that all need to be plugged into that port. I assume I can (get it? can lol) create a buss bar with a couple of connections for everything to tap into?
      For example I have a dash, a cruise control, a lap timer with video e.t.c all wanting to be plugged into the diagnostic port.
      Larry Callahan
      Founder / Administrator — Pro-Touring.com • G-Machines.com • HostMyJunk.com
      SEMA Hot Rod Industry Alliance Hall of Fame — Class of 2026
      Advertise on Pro-Touring.com • Shop Pro-Touring.com Merch
      Houston, TX
      Have you looked at obd2 y-splitter? Like this one?
      http://www.amazon.com/Docooler-16Pin.../dp/B000TMCX72
      130fe (his username) is using something similar for his Camaro.
      Tu Ho
      Firebird V2-LS swap
      Jan 2000
      Thanks but I'm trying to avoid a splittler on a splitter on a splitter.
      It seams like there should be a way to set up a buss bar unless there is some deal where wire needs to be kept as twisted pairs.
      Larry Callahan
      It's just the two (twisted pair) wires. I split them to connect my Dakota Digital gauges without having that bulky OBDII connector, or worse, two of those connectors, lol.
      ​John Parsons
      Jun 2010
      Oxnard,CA
      The wires can be spliced into in the back of the OBD connector, leaving the original for diagnostics. Just be aware that if all of those are to be tied into the can network, pins 6 and 14, if one device fails and brings down the network, it can bring everything down including the PCM and make it a little more difficult to diagnose.
      Chris Lansford
      69 Nova that's never done
      Jan 2000
      SCORE!!!!!
      Look what I just found!!!!
      https://www.wirecare.com/products.asp?prodline=dlm
      Larry Callahan
      May 2010
      kitchener,Ontario,Canada
      Thanks for providing the info Larry ....sure it will help lots of us
      Ryan Austin
      On Instagram ryanaustinss70
      Yep, good stuff!
      ​John Parsons
      Jan 2000
      After I order it I will post all the part numbers for the box and pins and connectors.
      Larry Callahan
      Central Wisconsin
      looks like standard Deutsh DT connectors.
      http://www.deutschconnector.com/prod...es_connectors/
      Caterpillar or most heavy equipment use a lot of these.
      Tim Mc
      71 Cutlass
      66 Tempest
      65 cutlass
      15 BMW GSA
