    Results 21 to 31 of 31
      Sep 2013
      Gary's 65...........Final Chapter
      A little past history of Gary's car........A couple years ago we added ridetech Coil-over suspension...Disc Brakes.....A/C......Aluminum Radiator and Electric Fans........anticipating the future swap of a LS engine into the car........Well.....The time is here.....Gary ordered a GM connect and cruise set-up........LS3 (480 H.P.) and a 4L70 trans.....
      So......Gary pulled the big block out at his house and brought the car over yesterday at 10 am......We swapped out the LS3 pan for a Holley 302-1 pan and some motor mount adaptor plates that I made up to raise the engine slightly to clear the front crossmember.......the car was originally a 6 cyl Powerglide car.....at some time in its past it was converted over to a 454 /turbo 400 car....... and during that swap, there was a second set of trans crossmember mounts welded in for the turbo 400 position......so....we had two sets of mounts on the frame......Works out easy for me as the new set-up uses the rear holes on the front mounts........a little sawzall action and I'll make up a couple small plates tomorrow to fill in the gap between the mounts and the everything is as simple as it can get......anyhow.....by 2 0'clock had the engine in and were finished for the day....
      Here are some conversion pics............
