Results 1 to 20 of 25
Thread: Fuel line routing questions
Hi gen 1 camaro ls3 ... Using Ptfe hose and a a vapor worx return less system.
first question I was considering running fuel line aprons the back of the engine. Specifically using resting clips that will bolt to the bellhouing. (Quick time so not to worried about the clutch coming apart and that being dangerous. So what concerns me about that location is the exhaust headers. The line will have to go over the top of them. thoughts or pictures of a si liar setup appreciated
second question ... If I run the line attached to the inside of the chassis it will end up real close to the mufflers eventually. If I run on the outer side of the chassis (think after market subframe And farm connectors) it will end up coming out by the lower suspension arm (where the leaf spring perch is) so what to do? Pics or ideas appreciatedFrom a place you will not see comes a sound you will not hear....
67 Camaro In progress
04-24-2016 #2
- Aug 2010
- Seattle area
- 360
No you keep it on the outside the frame ,and away from the heat.Just like the factory does.There is a reason why the factory does this.For safety and to keep the fuel from vapor locking.I run a 1/2 fuel line with Adel Clamps. on my 1979 Z-28 RS Camaro .Because it has a Supercharged small block Chevy.and it heeds the fuel volume.And if you are worried about the clutch exploding .I would get good quality clutch set up with a steel flywheel.And a scatter shield.Protect thy feet.
04-24-2016 #3
