      Feb 2009
      Supercharged engine gerotor fuel pump suggestion needed
      We are installing a gear drive paxton supercharger on a 289 Studebaker engine. Planning on running up.to 10 lbs. boost. Would like to use a gerotor fuel pump as they are quiet. Looking for a pump that would work with a regulator that will provide 5 to 15 psi to the carb. Anyone using such a pump? Maybe making 400+ hp.
      1963 Studebaker Avanti, LS1 motor set back 10 inches, T-56, Viper differential, Corvette suspension, C5 brakes, stainless frame.
      Apr 2012
      Woodstock, IL
      Holley makes several pumps that'd suit your application. For their "efi or carb" pumps you'll need a bypass regulator to get the pressure down, or they have some carb pumps that put out 7 psi or so.
      -Dale
      SchwartzPerformance
