      Alignment question
      Hi guys, I have a 67 camaro that I installed some DSE uca replacing the old spc arms. I still need a alignment. My camber is way off (positive). After I replaced the arms the front height is almost an inch higher. So my question is will negative camber adjustment lower the car? I don't have any alignment numbers right now, but usually run -1 camber. The way it sits now I have way too much positive camber. Hope somebody can help,thanks!
      Upper control arms shouldn't affect ride height unless something is binding. Did you tighten the control arm shaft nuts before letting the car settle to its normal ride height? Are the uca's the only change you made?
      Unless you have an unusual suspension design and/or wheel offset (think scrub radius), camber changes will have a very minor effect on ride height.
      67 Camaro, 96 LT1, 4L60E
