Thread: Camshaft help
04-19-2016 #1
- Feb 2016
- 31
Camshaft help
Looking for a recommendation, I'm building up a 383 SBC for my 67 Camaro. Im ordering up parts and I've been talking to a few different cam companies, right now that the only part I'm undecided about. Quick list of other parts for the build are,
AFR 195 with 64cc chambers
COMP Cams Ultra Pro Magnum Rockers 1.6
5.7 Scat I beam rods
Icon flat top pistons
RPM Performer intake
Hooker headers
Tremec 600 5sp
12 bolt w/ 4:11 gear
Compression should be around 10:7:1
OK so that's set, here are the cams,
110345-10
.565/.580 Valve lift
247/253 @ .050
300/306 advertised duration
110 lobe separation
106 intake centerline
Or this
Part #150-3103
Advertised Duration 292/294
.050" 233/235
.100 202/204
.200 152/150
.300 94/79
Lift .548/.510
Centerline 104/112
Lobe Sep. 108
I've narrowed it down to these 2 cams, please don't suggest anyothers. If you've been through the process of building a motor you know the frustration of going round and round with cam choice.
