    Results 1 to 17 of 17
      Bonney Lake, WA
      new project 67 camaro
      Picked up a new project. 1967 Camaro with a inline 6 and 3 on the tree. Ill be swapping in a 383 stroker, Mcloud twin disc, tko600 and then go from there. Not running when I bought it. New carb, and a few other things and it was good to go.Name:  20150714_185240 (1).jpg
Size:  293.2 KBName:  20150711_201146.jpg
      May 2011
      Brisbane, Australia
      Country Flag: Australia
      Looks like a clean car. Importantly, your misses looks happy with it!
      1966 Plymouth Fury III
      Nov 2010
      Quote Originally Posted by Godbolt View Post
      i think she is more happy that he is pushing ! Good luck though on the build!
      68 Camaro RS twin turbo
      Slow Lifted Jeep No TURBO :(
      Randal F
      Bonney Lake, WA
      godbolt. Shes quite the car girl. Her Dad raced back in the 60s and instilled the car bug in her. Im a lucky guy.
      Bonney Lake, WA
      started the engine swap. 383 stroker. scat ultralight crank, scat qlight rods, srp flat top pistons, roller hydraulic cam, pro billet roller rockers, afr195 heads. block was cleaned, clearanced, billet splayed 4 bolt mains, align bored, align honed, 30 over bored, honed with torque plates, square decked, canton road race pan with scrapers and windage tray, vic jr manifold with port match, and i dont remember what else. final assembly by dg machine in auburn, wa.
      Bonney Lake, WA
      engine pics
Size:  111.8 KBName:  20151024_182652[1].jpg
Size:  127.3 KBName:  20151024_195958[1].jpg
      May 2011
      Brisbane, Australia
      That ought to give it a bit more motivation! What's the basic plan for suspension and brakes?
      Bonney Lake, WA
      out with the old
      Bonney Lake, WA
      in with the new
      Bonney Lake, WA
      shes in
      Name:  camaro top engine.jpg
      Bonney Lake, WA
      The motivation is high godbolt. the driving weather is here. As for suspension im thinking but not sold on full truturn in front with stock lower control arm and spc adjustable upper, 1" dropped 550 or 600ish front spring and spend a few bucks on the shocks. Rear im thinking ridetech composite springs with good shocks. Brakes im still not sure but been thinking kore 3 hubs with c5 or c6 brakes. still not positive on a lot of this.
      May 2011
      Brisbane, Australia
      Looks great. Be good to be able to drive it with the new driveline and then do the rest when you are ready. Mine hasn't been driven for far, far too long...
      James
      Nov 2010
      James
      Very true on that... you might yourself ripping the car apart all summer! But I would definitely go after the brakes since you modified the engine! All that other stuff can be done over the winter when the snow and salt covers the road!
      Randal F
      Bonney Lake, WA
      with wheels
      Bonney Lake, WA
      just fabbed up a bracket to mount my ignition. couldnt figure out where else to put it. Digital 6 and new coilName:  ignition picture.jpg
      Bonney Lake, WA
      Afco radiator. welded on some tabs to hold fan shroud. Derale shroud, fan, and pwm system. Installed some aluminum nut certs for the blind nuts. Here it is all mocked up. need to do some electrical and clean up details.
      Bonney Lake, WA
      cooling system
Size:  253.5 KBName:  20160521_202402.jpg
Size:  261.8 KBName:  20160521_202421.jpg
