    Results 1 to 17 of 17
      Feb 2014
      SoCal
      Wheel clearance issues after Ridetech install
      Just installed a level 2 front and rear and now the wheel is outboard more and touching he wheel well lip. I thought I was suppose to gain clearance. Is it normal for the wheel to further out.
      1967 gto
      Dec 2010
      Fredericksburg, VA.
      You need to contact ridetech!
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Mountain Springs, Texas
      Front or rear wheel? Both sides? Did you have the front end aligned? To what specs?
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Feb 2014
      SoCal
      It's the front. Car hasn't been aligned yet but you can tell pretty obviously that the wheel is under the wheel well lip. Installation went smoothly. I really hope I don't have to get new wheels with a different back spacing
      Apr 2012
      Woodstock, IL
      Did you put any shims on up upper control arms -Dale
      SchwartzPerformance
      Feb 2014
      SoCal
      I didn't. It didn't come with any. I actually just thought about that now since it would bring the top of the tire in towards the frame. I will try that anyway. I already shot an email off to ridetech. Thanks again for ridetech order. Dale
      Apr 2012
      Woodstock, IL
      You bet. The shims may or may not be needed but that's strictly for alignment purposes so you'll want to do that. I've never heard of your issue before and it may end up coming down to the alignment.
      -Dale
      SchwartzPerformance
      You need to set it with -.5 degree of camber and 5 or 6 degrees of caster before getting worried about tire clearance. With no shims you likely have positive camber...
      Don
      Feb 2013
      Don
      This.
      An alignment will definitely help out in your situation if you haven't had it done yet.
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
      Feb 2014
      SoCal
      Thanks guys. I have an insane positive camber. My body shop has an alignment rack and I hope I can get it on there when the front end comes off for paint.
      Quote Originally Posted by keith4909 View Post
      The car needs to aligned fully assembled and at ride height. You could install a few shims in the short term until it is complete.
      Don
      Don
      Sep 2014
      You don't have to put it on a rack, just shim it by eye right where it sits. You don't want to run the tires into the fenders getting it on the rack!
      Feb 2014
      SoCal
      I adjusted the coils so it wasn't touching the wheel well. The shop needed to roll it around so lucky that worked for the short term
      Pensacola, FL
      Also make sure you have the offset cross shafts installed properly. If they are flipped around you'll have a ton of pos camber
      Feb 2014
      SoCal
      I installed the upper arm so the metal inserts were facing me. Should they be facing the engine instead?
      Feb 2014
      SoCal
      Got to work on it today. I rotated the cross shaft so the metal castor plugs were facing the engine and it didn't make too big of a difference. Not sure why that mattered to switch because the thickness of the shaft doesn't change so I have a feeling it doesn't matter which way they are installed. I then installed about 1in of shims on the upper arm and it brought the top of the tire in quite a bit. I noticed now, that it has quite a bit of outer toe. That will get fixed in no time.
      Pensacola, FL
      It matters because the shafts are offset. If they were straight like stock ones, it wouldnt matter. Here is how they should be installed.
