      Nov 2009
      East Tn.
      69 Camaro Vent Question
      I have a 69 Camaro and I bought a VA kit for it. My car has a hole in the center of the dash for the double center vent. The vent I bought is too small to fill up the hole. Is their trim that goes around the vent?thanks for any help
      Sep 2011
      Whitehall,Pa
      I would think you can use door edge moulding -4 pcs trimmed and glued
      Mountain Springs, Texas
      Deleted.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Jul 2016
      The dash pad covers up the remaining opening. I believe the 4 holes in the VA vent screw in the dash pad. I'm at this point as well. Think I might use the original ac vent with 2 holes.
      Use an original vent. It will look a lot better.
      Don
      San Antonio, TX
      Did you purchase a SureFit kit? Was it purchased for a factory air or non-air car? The non-air kit comes with a dual center louver and requires cutting the dash pad to install. The factory air kit re-uses the factory vents and includes adapters to attach duct hose to them. You can convert a non-air car to the factory air configuration by purchasing a factory air dash pad and center louver, but you'll need to acquire the correct louver adapters from Vintage Air.
      Could you post some photos of your install so that we can better understand the issue?
      Ryan
      KUL FIR CHICK N: COOL FIRECHICKEN
      '68 Firebird, LS7, 6spd, DSE all around.
