    Results 1 to 1 of 1
      Jan 2011
      Brisbane, Qld, Australia
      Country Flag: Australia
      Fuse & relays required for L92/LS3 harness
      Hi,
      I have an L92/LS3 with modified harness I bought from a member here. I'm preparing to start the engine for the first time and need some help on what relays and fuses I need. It appears I have everything except what would have been part of the OEM underhood fuse block.
      I'm a real beginner with electrics but looking for guidance on what to do in terms of ignition, fuel pump, powertrain relays & associated fuses.
      The unconnected wires I have coming from the PCM are labelled as below:
      • 12 v+ feed to fuel pump
      • battery & Fuse @ 20 amps
      • Starter feed from neutral safety switch (purple)
      • Engine harness 12 v+ key on fuse @ 25 amps (pink)
      • Unlabelled wire grouped with above wire (orange)
      Two of the above wires are already on a relay. (grey and pink). And that is not the engine harness wire.
      I have an areomotive stealth tank that came with a wiring kit that included an extra relay so I assume only a single relay for the fuel pump is required?
      There is also:
      • Fan 1 relay control
      • Fan 2 relay control
      • Tach
      • Speedo
      • Tap shift module control for auto trans
      • Brake light switch
      • Check engine light
      • OBD2 port
      Any help would be much appreciated.
