      Orlando, Fl
      Fuel line clamps / Plumbing solution
      Good evening folks.
      I have been on the search for fuel line clips just right for my application. My application shouldn't be too unusual. In setting up my Holley HP EFI, I decided to run hard lines for the majority of the run with short sections of flex line at the tank and from the hard line to the fuel rails.
      I have looked at most of the sources for off the shelf clips and nothing quite fits just right. Many of the clips available have a very small 10-32 mount hole. I wanted to use the stock mounts if at all possible, which use a 5/16" bolt. Single line clips are plentiful... But that won't exactly work for EFI apps with return lines. What I was after was an oval shaped insulated Adel clamp made for dual lines. I have found one source that supplies the aerospace industry with exactly what would work.
      George and I would like to gauge interest on these. Buying small lots is not very cost effective. We'd like to buy in bulk and potentially sell in small kits of the correct amount needed for certain apps. They are sized in 1/16" inch increments, similar to AN tubing. The material would be stainless with either an EPDM rubber or neoprene insulator. They would be sized to snugly clamp dual 3/8" lines.
      Please respond to this thread with any interest or questions. We would plan to buy in significant bulk to get the clamps down as low as possible.
      Nick DiPrenda
      Aug 2015
      charlotte
      I Like the the idea of a kit to run EFI lines and use stock mounting locations, sounds like great idea, count me in.
