      Jan 2013
      ST George UT
      1969 Camaro Project. LS2 super charged.
      I have a 1969 Camaro project.
      Right now its a 1969 camaro, solid floors, factory seats front and rear.
      Cowl hood.
      Quarters and doors very solid.
      All original sheet metal.
      Clean CA title in my name and currently registered.
      Front subframe was removed and powder coated gloss black.
      New tubular upper and lower control arms.
      All new body bushing.
      All new steering.
      New gear box.
      New disc brakes.
      Now for the rear end of the car:
      For the $10,500 you get the car as a roller. Rear will be on a custom cart.
      The trunk pan, rear inner tubs were removed for mini tub and 4 link. I have the DSE mini tubs and the AMD 1 piece trunk pan. Witch will be included at this price. But not yet installed.
      In the next couple weeks I will install the DSE mini tubs and 1 piece floor pan.
      Price will be $13,000 once this is done. You are welcome to come look, buy the cart and I will finish those and you can pick the car up.
      Extra parts I have for the car. THESE PARTS WILL NOT BE SOLD SEPARATELY..... DONT EVEN ASK.... IF YOU BUY THE CAR, YOU ARE WELCOME TO BUY ONE OR ALL THESE PARTS AT AN EXTAR COST.
      OK, here are the parts I have for extra $
      -LS2 motor, Turn key with Magnuson Super Charger installed. only 6,400 miles with all paper work.
      -Forge Line wheels and tires for a min tub 69 camaro.
      -Vintage A/C kit. New in the box.
      -Electric Life power windows. New in the box.
      -American Auto wire complete car harness. New in the box.
      -Billet hood hinges. New in the box.
      -Billet trunk hinges. New in the box.
      -Billet hood catch. New in the box.
      -Key less ignition system. Push button start. New in the box.
      -Iditit tilt column. New in the box.
      -DSE weld in sub frame connectors. New in the box.
      -DSE fire wall plate. New in the box.
      -DSE windshield wiper change over. New in the box.
      -DSE R/S change over kit.
      -DSE Quadra link rear kit. New in the box.
      -Carbon fiber sill plates. New in the box.
      -TLC custom fiber glass rear package tray with speaker cut outs. New in the box.
      -Baer 4 wheel disc brakes with master and booster. Used, only 300 miles on them.
      -Ricks Stainless EFI gas tank for mini tub car. New in the box.
      -New carpet kit. New in the box.
      -ATS alum knuckles (spindles). New in the box.
      -RPM built 6 speed Manual. New.
      -New dash pad. New in the box.
      -New head liner and sail panel kit. New in the box.
      -New stand alone LS2 harness and ECM. all new in the box.
      -Extra Cpp tubular control arms, New in the box.
      -Extra Cpp C5 brake kit up grade. New in the box.
      -Extra ARG power steering gear box. New in the box.
      -New front and rear bumpers. New in the box.
      -Billet side door vents. New in the box.
      -New 69 side gills. New in the box.
      -Dikota Digital VHX gauges. New in the box.
      -Custom Billet pedals. New in the box.
      This is just a small list of parts. I have 1,000 more. New gaskets, tail lights, on and on.
      DO NOT CALL AND ASK TO BUY THESE PARTS or how much for everything.
      You must come out in person to see all and talk price for everything....
      So to re cap.....
      car as it is right now.
      $10,500
      If I install DSE tubs and AMD trunk pan.
      $13,000
      With all the parts listed above must be done in person...
      I also have a 1968 camaro rs. Same owner last 35 years. Big project.
      With tons of pro touring parts.
      Location is Scotts Valley CA.
      Trying to load pictures. Give me a day to figure it out.
      Jan 2013
      ST George UT
      New 1 piece trunk pan is installed.
      Working on the DSE mini tubs this weekend.
      I will try to get pictures up tomorrow.
      Jan 2013
      ST George UT
      Pictures.
      Updated and pictures.
      I have mocked up the 1 piece AMD trunk pan.
      Also mocked up DSE mini tubs.
      I will weld them in this week.
      This is an older picture.. But the only one I can find.
      I will try and get more tomorrow.
      Jan 2013
      ST George UT
      LS2 super charger and wheels and tires
      Pictures of LS2 super charger and wheels and tires.
      Feb 2016
      Hi,
      Can you list your phone number please? Or PM me if you prefer.
      James
      Jan 2013
      ST George UT
      Current pictures
      A couple current pictures.
