      Jan 2014
      Sacramento, California
      ls2 swap starting issues
      so I have an ls2 swap and running a holley harness and ecu. I am getting power to coils and everything but never any spark for some reason. crank sensor is registering rpms ill attach a system log if anyone else is running the holley setup I can email you . I cant figure this out.. help!
      Jun 2010
      Deployed
      Many ls starting problems are related to the power supply. Many times people wire the ecm to a source that's interrupted when you turn the key. You need to make sure the power is constant even when the key is turned.
      1970 Camaro/DSE build
      Jan 2014
      ya its constant and wired straight to the battery for the ecu like it says.
      Jan 2014
      figured it out starter wasn't happy with the 2 gauge wire I was using to relocate to the trunk. so I relocated back to the engine bay and fired right up
