    Results 1 to 10 of 10
      Low budget LS swap
      Am wanting an LS motor for my 72 Nova (700R4; with a 12 bolt rearend 3.73 gears), of course on a budget. Would primarily be ued on the street with occasional track use. HP goal is 450 at least, and torque to match it. Am not sure what parts combinations would work here. Not sure if I am being realistic or not, but have $5500 dollars for this. Appreciate the input.
      Nov 2009
      Country Flag: Argentina
      Do you have a junk yard close enough that you can go and buy a 5.7L? With that done you can redo the existing wiring in order to save there. You would need an EFI fuel tank as well adn the 700r4 crank adapter as well. Your best bet is to price everything, maybe make a list here and people can chime in at the same time.
      I had a $10k budget and blew it out of proportion lol.
      Nov 2009
      double post...matrix in the internets
      Jun 2010
      Painted post NY
      $5500 is a decent budget. Do you have the 700r4? Is it built to handle higher HP? Hopefully someone who has done a nova LS swap will chime in ..otherwise you should look on ls1tech in the hybrid section for more advice.
      http://ls1tech.com/forums/conversion...ap-thread.html
      You should be able to get a LS iron 6.0... Do a cam swap and be near your HP goals. Intake and accessories may be an issue, the truck stuff does not fit well under stock car hoods. You will find all of the LS stuff pricey...mounts, oil pans, f body accessories, etc, items will add up quickly. You can drop a modern GM fuel bucket in your stock nova tank and be done..no additional vette regulator. Start reading through many builds...read a lot...a lot...and more. Good luck!
      Leon Reed
      1978 Trans Am
      LS1/4L60E
      my build..updated 11-21-13 https://www.pro-touring.com/showthre...8-TA-LS1-build
      Jan 2014
      Sacramento, California
      get an lq4 and do a cam swap. get it with the computer and harness convert the standalone yourself. Buy your headers, motor mounts and trans mount from the same company http://www.brphotrods.com/products/5...evy/index.html has decent prices. tanks inc is a good place to get your efi stuff. I bought my tank, fuel pump, sending unit and used the vette filter/regulator...you also have to remember your cooling system as well. need to get a new radiator and fans that will fit your application. also very important is your front accessories kit look at previous nova builds to see what works. if you get the lq4 you may have to convert to a fbody style waterpump the truck waterpump is different.
      my ls2 engine with ls3 heads and a t56 cost approximately $6500
      my headers $1200
      holley harness and ecu $1600
      motor mounts and transmission cross member $400
      front accessory brackets from lssimple I think were like $200
      could it probably be done with 5500 yes but honestly I would say you should plan on spending 4000-5000 plus the engine
      Jan 2014
      my headers $1200
      Jan 2014
      don't forget driveline, oilpan and gauges as well
      Thanks for the input everyone. Forgot to mention that I was planning on running a carb for the meantime and I have a 700R4 built for the HP and TQ goals. Figured I could save on the EFI tank. However, Leon you stated that I could get a modern GM fuel bucket in your stock nova tank and be done..no additional vette regulator? Not sure what you mean by that. I have been reading ALOT and am not sure which cam or heads to go with the 6.0. So many combinations etc.
      Jun 2010
      Painted post NY
      http://www.nastyz28.com/forum/showth...ight=FUEL+TANK
      This is a link talking about the vetteworks kit...which I used and have had no issues with for 6000 miles. You would need to shorten the height of the OEM GM fuel bucket to fit your early tank. That is not hard. No fuel pressure reg needed...4th gen has it built in. Here is a link over on ls1tech on how someone who thought they were buying a good quality tank, is not happy with results..FYI...no fuel tanks are "baffled" from the factory..none. The fuel bucket takes care of all of this.
      http://ls1tech.com/forums/conversion...nk-issues.html
      Not sure what fuel pump you would use if you went the carb route. External electric pumps work but are noisy and some are prone to short life. Going the carb route can be easier in that you have less wiring but you would need to buy a LS intake with controller ($600ish).
      Leon Reed
      1978 Trans Am
      LS1/4L60E
      Aug 2008
      jacksonville,fl
      Particularly with todays low gas quality, I think efi is much better for the street.
      On top of other good thoughts listed, anything you can fabricate, modify, & adapt yourself rather than just buying is a big saver. The small parts add up so fast.
      I did a 99' ls1/ t56 g-body install back in 2002 before all the kits. Paid $ 4600 to my door for a nearly new complete with harness, acc, fans etc. The t-56 still commands a healthy price today. Modified wiring harness, accessory location , mounts, etc myself. modified crossmember for oil pan, as there weren't aftermarket pans then. You can cut a longer used throttle cable &put a universal round screw on end on it for example. Like I said, the little things::::::
