    Results 1 to 17 of 17
    1. Any Knowledge on the 1928-34? Ford Hot Rods
      Hello,
      I was wondering if anyone knows much technically regarding the chop top custom Ford Hot rods...
      I read up somewhere that the Model T was like 103" wheelbase, the Model As up to 1933 were 106" wheelbase and the 33-34 model B ended up with a 112" wheelbase and the car over-all larger as well.
      In terms of pro-touring/Drag-racing and/or overall balance/stability of the vehicle at higher speeds...
      Is one better off with 103" wheelbase, the 106" or the 112"?
      So is there a model that is the preferred model year to do custom work on, or any model any year can look like any model any year?
      The picture I present is basically the sort I like... what year would I need for this?
      Apr 2012
      Woodstock, IL
      Short answer; you can't have drag racing and pro touring in the same sentence.
      Unless you have all wheel drive.
      -Dale
      SchwartzPerformance
      Beach Park IL
      28-31 Model A are 104"
      32 is 106"
      33-34 is 112"
      35-40 is 112"
      The car you pictured is a 32 Tudor Sedan. The chassis is heavily modified because giant engine. The axle is not supposed to be in front of the grill. Wheelbase on that car is at least 112" or more.
      Donny
      Beaufort , NC
      The Model A 28-31 is a whole different animal the the 32 and they are diff than the 33/34. I think you can have a traditional car or a drag or a pro touring but not all in the same car. Factory five would be the best bet for a fast great handling touring car.
      1992 Lexus SC400 daily SOLD
      1966 Porsche 912 Outlaw SOLD
      1968 Ford F-100 sb SOLD
      Beach Park IL
      Yeah, you sit _on_ a Model A and you sit _in_ a 32.
      Donny
    6. Hey and thanks for the replies...
      If I can get some clarity on a few points.
      32 is 106"
      33-34 is 112"
      35-40 is 112"
      Are you saying that is pretty much a 1932 with a 1934 wheelbase? - How would that look different to just buying a 34 model which already has the 112" wheelbase? - Trying to understand in this case, why buy a 32 with a 106" to move everything forward when you could of just got a 34 which already had the 112" - is the size of car different and the 34 would not look like that (in proportion) - as in, the 34 overall is longer (body wise) while this is a smaller car on a stretched wheelbase?
      Quote Originally Posted by Restomod View Post
      In what way are they 'whole different animal'? - Do they behave differently, drive differently, feel differently... can you elaborate on this?
      My question:
      Is one model more suited for drag racing/stability, while the other more suited for pro-touring... or will any one you get be pretty much the same?... I am coming at this from the perspective of the 1933 ridetech Car. I know it was completely re-engineered and so forth to be what it is... but what I am trying to get at is, they used a 1933. I remember the video around the track against lamborghinis and though it handled as good (possibly better) it was a 'bear' to drive compare to the lamborghini. So it behaved differently, the driver would have to use it differently to a lambo, but the results were there once you were used to its characteristics.
      So now putting that in context of say a 32 (with a modified wheelbase as the picture I posted), or a 32 with its standard 106" wheelbase, or even a 34 with its 112" wheelbase... would they all be the same (if built like the ridetech 33) and produce same results, just different characteristics to get used to, or is there a model with a more 'preferred' wheelbase/size that would make it run better simply because the size/stability etc is there that perhaps the other model does not have.
      Hence is there a preferred model, like "get 193x" would be the best one of the lot or there is no answer to this as those differences they have (like wheelbase) actually does not make a difference.
      What about the later 1920 - T models... or this is all together not going to cut it?
      Dec 2010
      Fredericksburg, VA.
      I'm not even clear on what you are asking. As such, I think most of this discussion has no possible way to provide any answer. Since virtually every hot rodded car of this style uses some sort of after market chassis and suspension, a discussion of handling characteristics of the different cars is pointless. The first thing you need to do is to decide if you want a drag style or pro touring style build and then locate the chassis most appropriate for that style build. The ridetech 33 started life as a Factory Five car as I recall and was subsequently heavily modified from what was delivered.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Beaufort , NC
      They are just different cars, you cant lump them all together. In fact the 28-29 A is different than the 30-31. I have had several A's and a couple 33-34's and i dont think any of them are "suited" to any drag or pro touring style. They all can be built to any style you wish as any other car.
      Mar 2015
      Baton Rouge, LA
      Quote Originally Posted by G-man View Post
      My question:
      All of the Fords, whether it be a 28/29, 30/31, 32 or a 33/34, are going to require equally as many chassis modifications to be any good at either going around corners or going down a drag strip. As such I think you should just pick the model year you find most pleasing to modify, because there won't be that substantial of a difference in performance right out of the box across any of the models anyways.
      Anyways I think it would be awesome if someone built a 32 like one of these:
    10. Quote Originally Posted by TheJDMan View Post
      What im trying to understand is more to do with a modified vehicle.
      So which "Base" car (model) would be more preferred if I wanted to build A: A drag car, or B: A pro-touring car.
      So eg: 1928 for drag racing and 1933 for protouring (after all the modifications are done to the base car).
      Since the sizes of the vehicles are different, I wondered which model would be more preferred for the build intended.
      Do you want 112" for protoruing and 104" wheelbase for drag racing (or vice versa) do you want the bigger car to start with (so 34) over a smaller 1930's and so forth...
      So im not thinking about stock form, Im thinking which model for a base platform would be more suited (due to its inherant size etc) makes which one of them better for which... or is it all identical. So in other words, if Factory 5/ridetech took a 1930 model Ford instea of the 33 or even a 1934... it would of been the same around the track as the 1933 because those things (Size of car, wheelbase) would have no actual effect on whether it was better/worse.
      This is what im trying to work out casue each one IS a certain size and each one DOES have a certain wheelbase... so which one is more suitable to start with to modify for either drag or pro-touring.
      Do I want a smaller car for handling or is a bigger one more stable and thus a 34 would be better suited than a 30 and etc...
      Hope that makes more sense.
      Mar 2015
      Baton Rouge, LA
      I think the general consensus here is that the model year (i.e. wheelbase) wouldn't make any insignificant difference for either a drag car or a pro touring build. In theory a shorter wheelbase means a car can change direction faster, but there are plenty of extremely quick cars that have long wheelbases (Z06 is 106 compared to 97 or so on a porsche 911 for instance).
      So in short get whichever model you wan't, because chances are it won't affect performance anyways.
      Plus it's kind of irrelevant anyways because the wheelbase wouldn't be a huge concern for these cars anyways if you have no fenders to worry about, the wheelbase will be dictated by what you make it when building the chassis.
    12. Thanks for that.
      So basically if I get a 28 or a 34... due to having to get a whole new chassis setup... that will dictate the length of the wheelbase. In which case a 28 could end up even bigger than a 34 based on that?
      Those Rat-Rod style customs... (like this http://www.motorfoot.com/gallery/mf/...dor-002-01.jpg) is that the same thing as what we are talking about here? (made out of the same models) or what? I looked up google for custom 32's and none of them look like that... smaller grill at the front etc... so dunno if thats the same stuff just customized different or whether they are a different car all together.
      Lastly... for those who did/do own these... what is the visibility like out of the windscreen etc after chopping? Are these even comfortable to drive, or is it more about looking different but pain in ass as far as comfort goes?
      Southern Indiana
      Why not just order up one of the Factory Five cars like ridetech built, then you CAN build it to handle and ride well and just ask Bret how to do it.
      Lee Abel
      AFTERMARKET PERFORMANCE
      Los Angeles
      Just buy the body you like and make a chassis to best fit your needs. It comes down to do you want a repo body or are you looking for an original steel body?
      I built a T Bucket in high school and it was probably the scariest thing I have ever driven.
      Since then I have built quite a few other "Hot Rods" and have always just purchased a body then created a chassis that works.
      This was the last one I worked on. He wanted more Drag but if you hustle it a little and steer it with the rear it does ok on a tight autocross course. I would have preferred a IFS with a rack.
      The rule is measure twice and cut once. My problem is I still measure with a mic and cut with an axe!
      Los Angeles
      Unless you are going to just putt down the street with no more that 150hp you will want to build a chassis from scratch, Boxing the original only gives you so much. The original frames were meant for 30hp and buggy springs.
      Mar 2015
      Baton Rouge, LA
      A lot of rat rods do have custom chassis, but they are made with lowering the car to the ground in mind and not handling.
      So yes, it won't matter if it's a 28 or a 34 because at the end of the day you'll probably have to build a chassis from scratch anyways, in which case the wheelbase is your choice.
      Beaufort , NC
      Visability is going to be bad out of a chopped coupe, they are small to start with and the more you chop and or channel it the worse it gets. My 34 truck was chopped 3 and channeled 7, tight squeeze!
      Sounds like you just need to call factory five and order up a 33..........as close as you will get to a all around car.
