      Feb 2010
      NE Arkansas
      LS swap related parts FS
      I'm changing some stuff around on my set-up and this is what I have to sell.
      I have this stuff listed on other sites so it's first come first serve.
      I am pretty firm on my prices. Rather than mark the price way up and haggle, I am putting the least i will take up front.
      1. Tanks Inc EFI retrofit pump. Works great and was putting 58lbs pressure at my rails. I changed tanks and don't need this any more. Sells for $229 + shipping on tanks inc's site. $150 shipped to lower 48
      The pump has been trimmed down to 6" to fit a 70-73 tank. I am also including the harness I made and the fittings to adapt to -6 and -8 an hose. I upgraded the bolts supplied with the kit to grade 8 allen head bolts.
      You will have to make another cork gasket, this one has shriveled up.
      Here's what it looked like in my 70-73 tank
      Here's the pump and what you will be getting
      2. Kwik perfomance AC retrofit Bracket. This is kit K10156 for engines with the Fbody LS brackets. Sells for $197 + shipping on their website. $165 shipped to lower 48 including the extras you need to make this work.
      Everything that came in the kit is included. I am also including the tensioner and gates belt that you have to buy separatly with this kit that runs around $65 and $30. This is ready to mount if you have the compressor and Fbody alt and PS bracket. You can also use this with a holley bracket but will need to change the belt and get their spacer kit for the drivers bracket.
      Here it is mounted on the car, left side.
      Here's the bracket
      3. 2010 style camaro exhaust manifold flanges and adapters. These will work with 5th gen camaro manifolds or Holley / Hooker swap manifolds. $45 shipped to lower 48
      I tacked welded one together, but can be separated if needed. The adapters will fit over 2.5" exhaust pipe.
      My build thread
      http://www.nastyz28.com/forum/showthread.php?t=241037
      Paint Jail Experience
      https://sites.google.com/site/paintjail/home
