    Results 1 to 10 of 10
    Thread: LS1 oldnews ?
      69LAnd
      LS1 oldnews ?
      Ok so now that they have LS2 engines on ebay ...does it make the lS1 a thing of the past? lol ....time to sell my ls1 hehe
      Rick M.
      hMMMMMMsss....
      1969 Camaro real RS SS DSE LS3 6M TWiiN TURBO in the make!(taking forever!!)..any donations apreciated hehe
      How much they going for?
      Stuart Seitz
      Jun 2002
      Long Island, NY
      The thing that I like is the LS1 has 7 years of aftermarket research behind it. They're essentially very similar engines, anyway. The LS7 will probably be a different story.
      Just as a crude example, in '99, Stage II LS1 heads made considerably less power than Stage II heads in '04. The aftermarket is what seals my decision for the LS1 (for this car atleast).
      Ontario, Canada
      All we need now is for the aftermarket to step up and start producing affordable blocks with a 4.00"-4.125" bore. Even a hybrid block (GenI block that accepts GenIII heads) would be better than nothing.
      Ken
      My other car is a Vega.
      Oakland CA
      but how much are those ls2 going for?
      Kenova if you find those parts let me know!
      David
      :3gears: 68 Rally Sport Camaro 350/4spd(t56ingarage)/8.5 10bolt 2.56 open,Hotchkis springs, kyb shocks, 17" Rallys 235/245-45-17
      1989 Pontiac Turbo Trans Am 3.8 Buick LC2 V-6 w/51k, Ported heads w/oversized one piece valves, te-44 turbo,PTS built 200R4 w/2800stall, Lucas green top 009 42.5# injectors, AFPR, Adjustable wastegate, ATR 3inch exhaust, Terry houston 3inch mandrel bent downpipe, stock intercooler w/duttwieler neck, Eibach Springs, Bilstien shocks, Spohn adjustable panhard bar...
      Feb 2003
      Houston, TX
      The LS2 isn't much of an advancement over the LS1. Its basically an aluminum 4.0" bore block and a different intake manifold. We have already had 4.0" bore blocks with the truck iron blocks anyways. The intakes are showing some promise however, as they retail (bare) for less than $250. Just need the fuel rails and such to make them work. All the LS1/LS2 parts are interchangeable. The LS2 heads are just LS6 head castings. The main difference is the location of the crank position sensor and cam position sensors on the LS2, but there are probably ways around that or ways to modify exisiting performance parts to accept them.
      Co-Founder, LS1TECH.com
      www.DV8Motoring.com
      May 2002
      Northern California
      hey David, did you ever find out how much they are? LOL just kidding. I tryed to do a search but no luck
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Feb 2003
      Houston, TX
      LS2 bare block is priced at $1K. Not bad
      See the LS2 forum at www.LS1TECH.com for details ;)
      www.DV8Motoring.com
      Ontario, Canada
      Nice price for the LS2 block. Now I just need an excuse to buy one.
      Ken
      Jan 2004
      East Windsor, CT
      Has anyone thought about the SLP ZL402 shortblock? 6.0 liter iron block, 4340 crank & rods, forged pistons. $3995.
      Supposed to be worthy of 575 HP, naturally aspirated with LS6 heads. Don't know what its upper limit is (power-wise), but if you were to add an intercooled Procharger....
      There's been some talk about it on LS1tech.com. Nineball, what do you think of it?
      Steve
