    Results 1 to 1 of 1
      Oct 2006
      Michigan
      67 Camaro pro-touring/driver
      I am thinking about selling my car, I hardly drive it so I am just curious what it's worth.
      1967 Camaro, it was a 6 cylinder car. I bought it as a roller a couple years ago. One of the previous owner's did some work on it. It had floor patches done and they didn't do the best job. So I fixed them with some grinding and welding. Car also had quarter panel skins replaced along with tail panel, doesn't look bad from outside or in the trunk. Car has no rust that I have found so that is good. Paint is driver quality, I would give it a 6 out of 10, has chips and imperfections. Drivers front fender had a patch at some point and has a small dent in it, I would replace the fender when painting the vehicle. Passenger fender was replaced before it was painted and is good. I have put about 750 miles on the car since I have had it. Everything below has that many miles on it except for the engine and transmission, they have 400 miles. The engine hasn't been dynoed yet but a conservative guess is 650 rwhp. Vehicle is tuned and runs on e85
      Things I have replaced with oer parts
      Windshield
      Drivers window regulator
      Weather stripping
      Headliner
      Carpet
      Door panels
      Dash pad
      A pillar moldings
      Package tray cardboard
      All interior moldings
      Radiator core support
      Front bumper(not installed yet)
      Head light brackets
      Outside mirrors
      Turn signal housing
      Aftermarket additions
      ENGINE
      LSA block, has piston oil squirters
      Bored/hones with plate to 4.070"
      Wiseco pistons, 10.2:1 compression
      Upgraded wrist pins
      Callies magnum crank
      Lunati H beam rods with arp 2000 bolts
      Clevite bearings except for camshaft, those are durabond
      ARP main studs
      ARP head studs
      Melling oil pump
      Ls2 timing chain
      ARP cam bolts
      LS7 lifters
      Trend hardened pushrods
      LS3 rockers
      LS9 camshaft
      LS9 cnc ported heads
      All new covers, front, rear, oil pan, GMPP valve covers
      ARP exhaust manifold studs
      All new accessories and starter
      Lokar dipstick
      Custom 4" cold air intake
      COOLING
      Griffin radiator and dual electric fans
      Custom heat exchanger with bosch pump for supercharger
      Frame mounted power steering cooler
      DRIVETRAIN
      Strange 9" housing with back brace
      Strange nodular iron center
      S-trac Diff 3.55 gear(1000hp warranty)
      35 spline axles
      3.5" aluminum DSS Driveshaft billet yoke
      Built 4L80E transmission
      Billet input shaft and forward hub
      Rollerized
      All new clutches and steels
      New electronics
      FTI billet tq converter 3200 rpm
      SFI flex plate
      Braided an lines and BM oil cooler
      Lokar dipstick
      SUSPENSION
      Ride tech 4 link rear with shocks
      Ride tech rear sway bar
      Scott mock front subframe with bent down rails. When I got this it wasn't square. I put about 15 hours into it and it is now perfect. The subframe uses rack and pinion sterring along with c5 suspension and ridetech coilovers. Has a 1.25" splined front sway bar.
      DSE weld in subframe connectors
      Solid aluminum body mounts 1/4" drop
      BRAKES
      C5 calipers
      KORE3 brackets
      Drilled rotors
      Hawk HPS pads
      Braided steel lines
      DSE Master/booster combo
      Line lock on front brakes
      WHEELS/TIRES
      18"X9.5" BOSS 338
      275/35.18 tires, rear are BFG drag radials
      FUEL SYSTEM
      OER stainless fuel tank, notched and modified with Tanks inc fuel sender
      Dual Walbro 450 in tank pumps
      Braided PTFE lines 8AN feed 6AN return
      Bosch motorsport 110lb/hr injectors
      Fuelab regulator and filter
      POWER ADDERS
      HARROP TVS 2300 Supercharger 13-14 lbs of boost
      8 rib front drive upgrade
      Devils own meth injection kit, turns on second fuel pump
      ELECTRICAL
      Modified FBody engine harness and computer
      All new body wiring and switches
      Digi-tails led turn signals and led tail lights
      Newer style head lights
      Alpine radio and amp, has hands free calling
      Rockford speakers
      Delay wipers, just like DSE kit but I made it
      Speed hut gauges, gps speedo, tach, fuel, oil, boost, coolant, wideband
      Trunk mount battery
      INTERIOR
      Ididit tilt column
      Momo steering wheel
      5th gen Camaro console
      Lokar shifter
      Billet rear view mirror
      Procar seats and rear seat cover
      Morris 3 point seat belts front and rear
      Billet gas pedal with lokar cable
      ridetech billet knobs
      EXTERIOR
      Eddie motorsport billet tail lights
      Ride tech billet gas fill neck
      DSE heater delete panel
      EXHAUST
      Kooks stainless headers, modified for v-band flanges
      Custom Y-pipe with Borla pro xs mufflers, all 304 stainless
      Pictures at the links below are from my cell phone along the process of installing parts.
      http://www.ottperformance.com/images/67camaro/hood.jpg
      http://www.ottperformance.com/images/67camaro/under.jpg
      http://www.ottperformance.com/images...aro/under1.jpg
      http://www.ottperformance.com/images...aro/under2.jpg
      http://www.ottperformance.com/images/67camaro/dash.jpg
