      Feb 2010
      NE Arkansas
      Spectre Fuel Tank venting questions?
      I just ordered a GM42BFI EFI tank for my 71 camaro and had questions regarding the venting for you guys that have one.
      I didn't see any kind of venting feature on the tank to release tank pressure? Is there something built into the pump / sending unit?
      If not how are you doing it? With a vented gas cap or something else?
      Wanted to have this figured out before I get the tank in case I need to order something. Wanted to avoid waiting another week after I get the tank.
      Thanks again
      My build thread
      http://www.nastyz28.com/forum/showthread.php?t=241037
      Paint Jail Experience
      https://sites.google.com/site/paintjail/home
      Feb 2010
      NE Arkansas
      Got a reply from a member that venting was part of the sending unit on these, so I think I am good
      My build thread
      Lawrenceburg, TN
      the factory cap was vented, and almost all replacement caps are also...no need to vent stock..such as and external pump system going to a carb....if you use an intank pump then it may need a vent....if you use a racing style fuel cap(like the ridetech style) then it needs a vent,,,.if your using fuel injection and the air flow needs to match the fuel flow....
      Appleton WI
      Rod,
      I'm currently researching this to install a tip valve and vent in my 68 Camaro. I'll be using the ridetech cap and a Rick's/vaporworx tank with pwm control and changing the Edelbrock 35520 over to a returnless system. How do I determine the vent air flow requirements without brake specific fuel consumption numbers due to the current return system?
      Also, venting the tank into the car makes me nervous. Where is yours vented?
      Jim
      1968 Camaro --502HO, ATI 10" TreeMaster, Hughes TH400 with Gear Vendor's OD, Moser 12-bolt, RideTech StrongArms and MuscleBar, Chris Alston G-bar rear suspension, 2 1/8" by 4" Lemon's Headers through 3" Pypes X-pipe and Hooker AeroChambers.
      Mountain Springs, Texas
      Quote Originally Posted by camrat68 View Post
      Rod,
      Jim
      Never mind....
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Apr 2016
      Check out II Much venting system as I am doing research on tank venting as well
      Appleton WI
      Never mind....
      I'm sorry?
      Jim
      Appleton WI
      I see now.
      The II Much side-mount with integral filter should do the trick. :D
      Jim
