      Feb 2013
      Morgantown, WV
      69 Pro-Touring Camaro
      1969 Pro Touring Camaro
      Asking Price: $62,000
      Included with the sale of the car is every receipt in 2 three ring binders sectioned off and categorized by Engine, Engine Accessories, Transmission, Brakes, Muffler, Fuel System, Exterior, Sound System, Wheel/Tires, Electrical, Front Suspension, Rear Suspension, etc. This same information is provided in a detailed Excel Spreadsheet that totals the build price in parts alone at $100,027.79. I can send this spreadsheet via email to serious potential buyers. Also included is a certified appraisal report that values the car well over my asking price. This too can be provided. I have an EXTREME amount of build information, pictures, etc.
      Engine:
      • Scott Shafiroff Racing Engines custom build Dart 540 BBC.
      • Dart Big "M" 9.8" block with splayed 4 bolt main caps 4.56 inch bore, 4.25 stroke
      • Callies 4340 Dragon Slayer Forged Steel Crankshaft
      • Dart Pro 1 Aluminum Heads 325cc Intake Runner, 119cc combustion chamber w/ titanium retainers
      • SRP Pistons Forged Hi Silicon 9.9:1 Compression
      • Shafiroff Forged H Beam Rods 190,000 PSI
      • Pro Systems 1000 CFM Carb
      • Be Cool Radiator with Twin Spal
      • BBC Serpentine Belt System
      • MSD Digital 6 Plus Ignition System with MSD Blaster HVC Coil
      • Victor Jr Aluminum Single Plane Intake for 4150 Series Holley Carbs
      • Shafiroff Mechanical Roller grind 8620 steel billet
      • ATI Super Damper
      • Fel Pro Gaskets
      • MSD Pro Billet Distributor with Carbon Composite Distributor Gear
      • HIPPO Hi Pressure Pin Oiler Roller Lifters
      • Headers Custom Made from Lemons ceramic coated
      • Moroso CNC Billet Aluminum Hi-Volume Oil Pump
      • Edelbrock Victor Jr Perma Star finished Water Pump
      • Moroso Street Vacuum Pump
      • Advanced Plating Tall Hi Perf Valve Covers
      • All Stainless Steel Braided Hoses and Anodized A/N Fittings everywhere
      • Hyrdratech HydraBoost brake System with all stainless steel brake lines
      • Magna Flow Mufflers 3 inch exhaust with X Pipe
      • Built to Run on 93 octane pump gas
      • Actual Dyno Sheet 682 HP@6000 RPM, 648ft-lbs. torque @ 5000 RPM on 93 Octane Pump Gas
      Transmission
      • Tremec T-56 Magnum 6 Speed
      • B&M Shifter
      • QuickTime forged Steel Bell Housing
      • Detroit Speed and Engineering T-56 Cross Member
      • Hydramax Hydraulic Clutch
      • McLeod Hydraulic Throw Out Bearing
      • Ceramic Clutch Rated at 750/lb tq capacity
      Rear
      • Detroit Speed and Engineering Quadra Link with Ford 9" Axle Housing and 31 Spline Axles. Koni Adjustable Coil Over Rear Shocks
      • 3.50 Gear Ratio
      • DSE Koni Aluminum Housing Coil Over Shock
      • Truetrac differential
      • Baer Track System Claw Rear Disc Brakes with Drilled and Slotted Rotors 13 inch
      • Detroit Speed Mini Tubs
      Front Suspension
      • Chris Alston Chassisworks G Street Coil Over Conversion with Vari Shocks Double adjustable for rebound and comperssion. shockwave upper and lower control arms
      • Detroit Speed Power Steering Pump Polished Aluminum
      • Detroit Speed Weld In Sub Frame Connectors
      • Unisteer Rack and Pinion
      Interior
      • Corbeau Racing Bucket Seats
      • I have a Recaro Child Seat in the rear for my 6 year old
      • Painless Wiring Fuse Panel
      • Entire interior has Dynomat
      • JL 1 Inch Tweeter, 4.5 inch kick panel speakers, Infinity 6x9s, and Kicker 10in sub. 2 Kicker Amps. Alpine Receiver with I-Phone connector
      • Autometer NV Gauges
      • All New Carpet/Door Panels/Headliner
      • I Did It Tilt Steering Column
      • Flaming River Water Fall Steering Wheel
      • Detroit Speed Dash Insert wrapped in Carbon Fiber
      • New Glass New Seals
      • Billet Window Cranks
      • All New Dash Components
      • Detroit Speed 7 Speed Wiper Kit
      • Lokar Pedals
      Exterior
      • Dupont 1999 Corvette Torch Red with Dupont 1997 Grand Prix White Stripes
      • Ring Brothers Billett Aluminum Hood Hinges
      • JW Speaker 8700 Evolution LED Headlights
      • ZL-2 Cowl Induction Hood sale of car also includes all Fiber Glass 4 Cowl Induction Hood painted to match
      • Detroit Speed electric headlamp conversion
      • Deroit Speed 19 Gallon Stainless Fuel Tank
      • Aeromotive A-1000 fuel pump
      • All Stainless Hoses on Fuel System and AN Fittings used everywhere
      • All New Bumbers, Drip Rail, Chrome Window Trim etc
      • optima yellow top battery located in the trunk mounted in Detroit Speed Billet Battery Holder
      Video can be seen at: https://youtu.be/_nTvMsmVg_s
      Feb 2013
      Morgantown, WV
      Bump for new price $60,000
      Feb 2013
      Morgantown, WV
      Open to offers?
      Apr 2011
      Love what you've done with this car...outstanding! Sent you a PM, not sure if it went through.
      Feb 2013
      Morgantown, WV
      Sold!
