    Page 2 of 2 FirstFirst 1 2
    Results 21 to 24 of 24
    1. #21
      St George Utah
      Quote Originally Posted by TerryD View Post
      Great Blake! Sorry for all of the questions, a lot of choices out there! The additional info helps with the decision making process.
      So I assume that the front link on the torque arm is dry?
      I will be contacting you in a month or so toorder the Track Time front suspension set up. What is the lead time for shipment? I am going to handle the front first as I will have the engine and trans out for replacement. I am trying to locate a donor stock front subframe....no luck yet but I am looking!
      On the rear. I won't be mini tubbing this one. Any reference you might have on tire wheel combo would be helpful. When I get with you on the front suspension you can quote me for the floater option on the rear housing.
      Terry
      Yes the front mount is dry
      WE normally have the Subframes in stock or in production usually no more than 2 weeks.
      Rear wheel tire a 9.5 with 5.5 bs works well and a 275 tire
      Blake Foster
      www.speedtechperformance.com
      435-628-4300
      St. George Utah.
      it's always sunny here.
    2. #22
      Dec 2012
      3" over axle exhaust, 800 foot Lbs of torque .... NO problemo
      Steve
      Build it right ... 'The 2nd Time !!'
      69' SS/RS X11 PRO-TOURING E-Force LS7 - SOLD
      2 Custom FJ40's -SOLD
      77' 911 Hotrod - SOLD
      'Killer Piggy' 73 FJ55
      67 Camaro - TBD
    3. #23
      Apr 2012
      Richmond, Texas
      Quote Originally Posted by sheck44 View Post
      Steve
      Steve,
      Great pic! A couple of related questions for you....how did it go with the install of the torque arm brackets to the 12 bolt? And what subframe connectors did you use? Beautiful car!!!!
      Terry
      My '67 Nova Build Thread http://www.stevesnovasite.com/forums...d.php?t=218954
      '73 TA build. @projectarrowhead73
    4. #24
      Dec 2012
      Terry .. Thank you
      Fairly easy connection, I've done 3 now for guys up here. Just need to grab the grinder and take off some of the drivers side flange. About 10 minutes worth of work. I also found the 2 connection bolt heads to be too tight a fit into the top plate mount and the heads bind a bit when you crank it down. I just run the side of the heads through the bench grinder a little and she cranks down much easier. Honestly cannot remember which frame connectors I used, bolt in obviously, BUT if you have weld in connectors make sure you install in the correct order with the Speedtech front winged piece before you install the front subframe .... Its a beeyatch to install that after
      Cheers
      Steve
      67 Camaro - TBD
