    Page 7 of 16 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 ... LastLast
    Results 121 to 140 of 318
    1. #121
      Dec 2015
      Ruhr-Area, NRW, Germany
      Country Flag: Germany
      Taking delivery of the drivetrain and rear axle in a few days! Stay tuned for pics!
      1985 Dodge Power Ram W250 3/4t 360/518/241
      2005 Dodge Ram 1500 SRT-10 505/T56/D60 small upgrades
    2. #122
      Dec 2015
      Full ahead!
      More stuff shows up:
      Caliper bolts, hood bumpers (dry rotted) (and new line wrenches, i destroyed the cheap ones i had):
      @Mike:
      Will be picking up the spindle and balljoint mounts on monday!
      I'll be working on the front suspension in the next few days.
    3. #123
      Jun 2014
      Loving the quality of this build. I'm stuck using junkyard parts this go round. One day when I grow up...
    4. #124
      Dec 2015
      Thank you!
      I am trying to use parts that are commonly available. My JY is Ebay.
    5. #125
      Dec 2015
      I went and ruined a new Moog LCA just to cobble something together.
      Followed by mockup time:
      It looks like the LCA bolt and ball joint are in one plane = the LCA sits level at ride height.
      Had to install the caliper... these look even larger when installed on the truck.
    6. #126
      Nov 2010
      Looks like everything is going to work out as planned....
    7. #127
      Dec 2015
      I still have no clue how to mount the UCA... It's not something i should think about today, i am having one of these clumsy, "better stayed in bed"-days...
    8. #128
      Nov 2010
      Quote Originally Posted by kingcrunch View Post
      I know the feeling.....
    9. #129
      Dec 2015
      Turns out it's not just "clumsy, better stayed in bed" but i came down with a cold. Half of the week lost to headaches and a running nose.
      And i couldn't even figure a way to mount the D60 HD (Ram SRT10) with its 3.5" axle tubes to the trailing arms.
      I dug up a source for custom made axle perches (CaptainFab over at www.67-72chevytrucks.com) but i still have to:
      - find someone to custom make two sets of 1/2" (or 9/16") x 4.125" x 10" u-bolts
      - find a way to modify the trailing arms to accept the aforementioned u-bolts
      They are like an inch or so wider on the outside than stockers.
      More headaches for my running nose. On a positive sidenote: The old 225 engine is sold.
      After researching/googling "uca mounting tabs" for hours i have several ideas for the UCA mounts and i ordered a cheap used Ram 1500 UCA over Ebay for mockup.
      Signing off for today, heading for my bed. Snuffle.
    10. #130
      May 2012
      Mississippi
      kingcrunch,
      I've been following along and it's nice to see someone thinking outside the box on a different platform thatn the norm.
      I have a 1979 Dodge (LRE) truck that I want to lower and give a more protouring stance. One thing I noticed in the past
      that may need to be addressed on your 85 also is front frame flex. My truck has 275-60-15s all around now and I noticed
      when stationary and turning the wheel there is noticeable frame rail flex at the steering box.
      Dwayne
    11. #131
      Dec 2015
      Dwayne,
      yes, i have noticed that on my '76 W200 and my '85 W250.
      There is a factory bracket and repops of that bracket available that triangulates this part of the frame into the front crossmember.
      But i don't like the stock steering setup at all and power steering boxes only go down as far as 14:1 ratio.
      I hope to be able to put a rack and pinion steering gear in this truck.
      Alex
    12. #132
      Dec 2015
      Modded control arm does not work as intended... did not see that before cutting although it was obvious.
      Looking at cutting the front suspension crossmember from a '05 Ram and making something from that.
      All kinds of other problems with that:
      - Track width differs by 3"
      - frame width is far from close (the ouside width of the D150 frame is 1" less than the INSIDE width of the 1500s frame).
      - 1500s frame is boxed, D150s frame is open
      I might have to look at C10 suspension parts again. I still have that C20 lower control arm in my parts stash...
    13. #133
      Dec 2015
      Something's coming up, gotta clean out the hallway.
      I removed the inner fenders to free up some space here and make removing the 225 easier.
      I also found a place that will cut the front section of a 05 Ram 1500s frame off for me. The price is ok. Nothing of that stuff is cheap over here...
      And i badly need some kind of progress on the front axle. Kind of an act of desperation.
    14. #134
      Nov 2010
      Too Bad, I have a complete 2005 SRT10 chassis that I would have given you, I can't get rid of it, Probably going to go for scrap..
    15. #135
      Feb 2008
      saint clair shores, michigan
      Quote Originally Posted by Tincup View Post
      No no no no no noooooooo! That's a shame though
    16. #136
      Nov 2010
      Quote Originally Posted by GRIMMEY71 View Post
      Come get it, you can have it.....
    17. #137
      Dec 2015
      OH YEAH BABY!
      And then i thought, oh shoot, this axle is damn wide.
      I have a regular 8-lug D60 stealing space in my shop and i thought this thing was big.
      This SRT-10 axle is even bigger. 3.5" axle tubes really do look huge in person.
    18. #138
      Dec 2015
      The rear axle is in fact too wide.
      It's 1776mm WMS to WMS. Put 9" wheels with 25.04 offset on there (this is the SRT-10 replica wheel in 20x9") and you have 1955mm from rim to rim.
      The trucks wheel arches in their stock form have a spacing of 1942mm, from the inner lip of the wheel arch to the inner lip of the other wheel arch.
      I can make it fit but it's still very tight and that's not taking into account any tire on the wheel. I am considering getting the axle shortened by 40mm on ONE side.
      I am thinking about moving the pumpkin over to the passenger side to offset the drivers weight.
      What do you think about that? I am not really sure it's a good idea yet...
    19. #139
      Minneapolis, MN
      If you went with some custom or different wheels, you could change up the offset. I know I have some Enkei's on my race car that are 17x9.5" with a +38mm offset, and I had some 17x9 with +45mm on another car. But if you really like those wheels, I could getting it narrowed.
    20. #140
      Dec 2015
      I am looking into rolling the lips of the wheel arches. Should be good enough.
      The 5x5.5 bolt pattern really gives me fits though.
      There is about two wheels i could use (SRT-10 repop or OEM wheel, both 20x9).
      Both are too narrow for the tires i want to run (285/35 R20).
      So i am turning back to european manufacturers and these have nothing that might fit the wheel centering on the front wheel bearings and rear axle shafts.
      Yay!
      I also just found that the Rams hub/wheel bearing does not lend itself to be re-drilled for a 5x4.72" (5x120mm) bolt pattern.
      ARGH!
