Results 1 to 10 of 10
Thread: DSE Gas Tank Install Question
12-21-2015 #1
Purchased a DSE (Rock Valley) Minitub tank (with built in LS fuel pump) to go with my Accel Superram fuel injection.
Reading a lot lately about not using regular braided lines (fuel smell) and better way to go is to install Teflon braided lines.
Going with Russell Powerflex - pre-made crimped hose ends to run the entire length of the car:
http://www.summitracing.com/parts/rus-658490
Since I am going with a Teflon hose - I have not see any hose ends that at 90 degree SWIVEL to a 3/8 npt - they are available for regulator braided hose but not Russell Power Flex (and I also checked with Aeroquip for their Teflon hose).
I found this - a brass 90 degree male and female ended 3/8 npt fitting - made for transmission lines:
http://www.summitracing.com/parts/prm-15157
Plan is to use this install on the top of the tank then use a regular aluminum 3/8 NPT to 6 AN Russell fitting - then above noted pre-made hose the length of the car.
Just looking for any thoughts or comments if ok to use - Thank you
