      Feb 2014
      SoCal
      Tranny recommendation
      1966 gto
      Running a period correct motor 474 roller motor. 480hp/650tq
      12 bolt posi with 3.07 gears
      full stage 2 ride tech single adjustable
      4 wheel wilwood disc
      18's all around 275/35/18 rear tire
      looking for an automatic overdrive 4/5 speed that will go in with little to no modification. Not looking to cut up tunnel. Would like a nice deep 1st/2nd gear. Don't mind electronic controlled. I can get a stand alone system.
      Thank you
      Apr 2012
      Woodstock, IL
      With that torque, I'd say your only choice is to go 4L80e. The first gear may be a bit low for your 3.07 gear though, but that torque should still pull you out of the hole ok.
      There are adapter plates available from Trans Dapt and some others.
      As far as fitment, I don't believe there's much if any mods required to the tunnel.. But we've only swapped maybe 1 of those into a stock frame early A-body like yours, a few years back.
      -Dale
      SchwartzPerformance
      Petersham ,ma
      How about a turbo 400 with a gear vendors off the back....would be simple and strong
