      Nov 2014
      Chilliwack
      Ridetech 4 Link Spring Rate
      I'm getting ready to order a ridetech 4 Link with HQ Coil-overs for my 1969 Mach1 I need some help deciding on the spring rate. It's a street car, I would like it to be fun to drive in the corners, but still have a decent ride.
      Jan 2014
      Portsmouth NH
      I am sure the guys at ridetech will have so advice. Make sure to give them a call. You should also try out the spring rate calculator on there website. http://www.ridetech.com/tech/spring-rate-calculator/
      Feb 2013
      Hey!
      Out of the box, the setup is dialed in for a nice driving/performing street car. If you're wanting something to primarily drive on the street but something you can still take into the corners, I would recommend staying with the kit as it is. If you were wanting to build more of a track oriented car, we could jump up in spring rate but the ride quality will be slightly hindered.
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
