    Results 1 to 12 of 12
      Jonesboro, Arkansas
      Oil Catch Can Question..
      Does anyone use a oil catch can on early Chevrolet engines? I see a lot of information on the LS engines, but I haven't found any for Early models.
      On another question, What do you guys think about this http://www.automotivepartsfactory.co...-80705015.html being used for a radiator overflow on a '68 Camaro? The '68 never had one (overflow reservoir) and thought this would be pretty cool and it has a sight glass. Of course if someone else has any ideas I'm all ears.
      Carl
      Carl Wilson
      what's your question on catch cans ? I run two on my BBC
      Chris Luxford
      68 Camaro 632 BBC
      61 Buick Lesabre - Daily Driver
      06 Prius - Wife's a tree hugger !
      Mar 2013
      San Jose,CA
      I run a moroso on my sbc
      LS3 1967 Camaro RS
      Jonesboro, Arkansas
      I'm guessing these are not LS motors. I have a SBC (non LS). How did you hook these up, and what did you use?
      Carl
      Carl Wilson
      Oswego il
      This, except route them to a vented catch can. You can plumb them into the valve covers anyway that works for your engine compartment.
      Youre just routing the pvc system to a container.
      http://www.speedwaymotors.com/Speedw...Tube,1887.html
      Dec 2010
      Fredericksburg, VA.
      Carl,
      That catch can you linked to looks like a pretty good deal for $39. I don't currently have an oil catch can but I may have to buy one of those.
      Steve
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Jonesboro, Arkansas
      Carl,
      Steve
      Yeah, I think so too. I was also wondering if I could incorporate the same piece into a radiator overflow. I like it that it has a sight glass on the outside.
      Carl
      Carl Wilson
      I have two of these, one for each bank, run braided line from front of valve cover to the can. http://www.jegs.com/p/Aerospace-Comp...49803/10002/-1
      Chris Luxford
      68 Camaro 632 BBC
      Nov 2009
      the dirty mitten
      My thoughts are that every engine should have a catch can. A vacuum on the crank case is great for many reasons but that will draw oil into the intake coating it with junk. That can you posted looks fine for a catch can, but not a radiator overflow. An overflow tank needs only one port and it needs to be on the bottom so that the radiator can draw in fluid, if it tried to draw in fluid off that one it would only get air, plus you would want a cap to fill it with. Take your pick, they are about the same price
      http://www.automotivepartsfactory.co...&Submit=Search
      Steve
      Jonesboro, Arkansas
      I like that the oil catch can has a sight glass. I think if you hooked a hose up to the inlet, that went to the bottom of the can it could be used for a radiator overflow. The other inlet could be left open so as not to build up pressure. I see what you mean about a fill cap though. It looks like the top might come off with the exception of the cutout that the mounting bracket goes into. I might look at some of the original plastic housings that are translucent if I can't find something I can check levels with. I really like the looks of the aluminum though.
      The overflow on my Chevrolet truck, and on my wife's Mustang, and just about all the others I've seen go into the top with the hose going to the bottom of the tank is the reason I mentioned that way.
      Carl Wilson
      Nov 2009
      the dirty mitten
      Yeah, if you could get one of those fittings to have a hose go to the bottom of the tank, that could work. Maybe then figure out a way to use the other fitting as a fill spot. You could also add a sight glass to their radiator overflow tanks if you are still set on needing one
      Steve
      Jonesboro, Arkansas
      That's an idea...
      Carl Wilson
