      Nov 2015
      Gbody frame notch.
      I have an 87 cutlass supreme. I need to fit 11-11.5 tire under wheel wells. I have seen the notching done and a mini tub. Can notching get me there or should I just go mini tub. I am getting aftermarket wells too. Budget build so I would appreciate any insight
      Apr 2012
      Woodstock, IL
      I think you'd need to notch AND minitub, no?
      -Dale
      SchwartzPerformance
      Nov 2015
      Ok. So if u could help on a mini tub Wat all does it entail?
      Nov 2015
      Just doing the wheel wells....
      Dec 2015
      Mississauga, ON
      You need to look at the backspacing/offset of the rims you are planning to use. Get the wheel off, set the suspension at ride height and measure how much room you have under there.
      If you are going to notch, have a look at this:
      http://www.maxchevy.com/tech/2008/iii_8-frame-1.html
      Feb 2012
      Central NY
      You will need a notch and tubs to fit that wide of a tire. You will need to cut out the old tub, I would buy premade wheel tubs and cut the floor and new tubs to fit. You will also get into the supports for the trunk hinge that are spot welded to the tubs. Not hard, but very time consuming....
