      Feb 2014
      SoCal
      How long to install level 2 non air Ridetech
      Any a body gm muscle car
      64-72
      I just swapped out my 10 bolt for a 12 bolt and it took about 2 hr with bleeding and no lift. I'm pretty quick and have a good back ground in auto repair. Just want an idea so I know how much time to set aside. I would be doing it solo. Car has 4 wheel disc of that matters.
      Feb 2013
      The A body kit is pretty simple to install, no welding, no cutting, just bolt on parts. If you're doing the level 2 coilover kit, bolting the pieces on will take you a few hours. Getting it set at ride height, fine tuning the shock valving for your liking, and getting the alignment set are the only parts that will require any more time. You could have it done in a day, pretty easily.
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
      Feb 2014
      SoCal
      Wonderful. That's what I was thinking too. Thank you for the quick response.
      Feb 2013
      No problem, let me know if you need anything!
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
