    Results 21 to 27 of 27
      Newbury Park, CA
      Another DC Controls story
      After some mild apprehension, I too took the DC Controls plunge.
      There were two reasons. First, the temperature switch did not have the temperature range that was ideal for the engine. There are no switches available to do what I wanted, both from a temperature and fitment (thread size, connection, etc.) standpoint. The second is that when the fan was running at full power it took the idle speed down 100-150 RPM, which meant having the idle speed a bit to high in order to compensate.
      The controller is very compact, smaller once in-hand than what one would expect (even with the drawings.) Easy to wire, and great instructions. It is mounted totally inside of the MarkVIII fan housing, no wiring out the front like their website shows. Four small self-tapping screws inserted from the front hold it in place. With a full depth shroud, there is still over 1/2" of space between the contoller and the radiator.
      Best of all, it works exactly as advertised. With the temp probe set at 166* and inserted near the radiator output, the fan kicks in at 185* engine temperature. No more 15* temperature swings. Due to a bit of lag between engine and radiator temps, the engine temp dips to 180* before shutting completely off. There is little lag time between 180* and shut off, so over-cooling is minimized. I may experiment with some type of modified 3/8"-NPT fitting to mount in the head to fit the temperature probe into.
      The only thing it needs is a noise filter. Dummy me forgot to read the accessories page in detail and order one. It's real easy to tell via the stereo the ramp up/down speed of the controller.
      All in all, a nice part.
