    Results 1 to 1 of 1
      Aug 2015
      1963 Chevy Nova Convertible LS
      1963 Nova Convertible
      6.0 Turbo LS Motor
      Asking $41,000 OBO
      Featured in Car Craft and Chevy High Performance Magazine.
      Seen on MavTv for optima Search for the Ultimate Street Car
      Competed in the “Muscle Car of the Year “ 2014
      There is a Feature article in November's Chevy High Performance on News stands Now.
      Nova was built and finished in 2014.
      There is now about 800 miles on it.
      The car was asked to compete in the 2014 Car Craft Magazine “Muscle Car of the Year.” (link below).. Car was also used by TCI Engineering as a test car. Car was also at Car Craft Nationals in St. Paul Minnesota. There it won the Best Pro Touring Car by Editors. (link below). Competed in the Real Street Eliminator at 2014 Car Craft Nationals. Also Chevy High Performance Magazine did a photo shot on the car (link below)
      Car was on MavTv for the optima's Search For The Ultimate Street Car. This car attacks a lot of attention.
      Here is the info on car.
      Motor is a Stock block 6.0 . All that was done to the lower end is new rings, ARP rod bolts. There is a Holley oil pan, Stock GM LS6 cam. Heads are LS6 that were ported and a set of PAC springs installed. Intake is a stock LS2 GTO with Stock drive by wire throttle body. There is a set of Lingenfelter 60lb injectors. Turbo is a 72mm Turbonetics with a custom intercooler made by Topline Design & Speed. Tial wastegate and blow off valve. There is also K&N filters on the intake and breathers. Radiator is a AFCO with a Spal single fan. There is a set of Holley Cast manifolds feeding a Dyno Max Muffler.
      Transmission is a 4L60E that was all redone with the best parts.. Converter is a 2800 stall from PATC. There is all Hardened internal parts to hold the power of the motor.
      Rear end is a GM 12bolt with Ford 9in ends and narrowed By Topline Design & Speed. There is Mark Williams Axles and a Truetrac posi with 3.55 Strange gears.
      Brakes are 14in Brembo 6 piston front and rear. Car stops on a dime.
      Front and rear suspension is all TCI. Front end is a Mustang 2 with a power rack.
      The rear end is a 4 link from TCI.
      There is Viking coil over Adjustable shocks all around.
      Wheels are TSW 18x9 front and rear.. Tire are Nitto NT05 275/35-18
      Stock fuel tank with a custom made drop in fuel pump. Fuel pump is a Aeromotive A1000 and a stock Gm regulator. All AN fittings on all fuel lines. There is also a fuel cooler on the line.
      Roll bar was made to be removed. The interior is stock with the exception of the Dakota Dash and Kenwood CD played. It also has a B&M shifter. There is original seat belts in the rear and ridetech 5 point harnesses in the front. The complete interior was also repainted.
      Paint is a 2013 Ford Mustang color (Kona Blue) Body is awesome and flawless. Top is in great shape no problems. There is also a boot to cover the top when down. Front splitter is a Custom made out of Aluminum. There is no decals on the car now.
      As I stated in add. This car was finished in 2014 and everything was replaced or worked on. This car can be driven anywhere. Turbo doesn’t start working till over 3000 rpm. Car made 500hp at 5 psi and 700hp at 15 psi. There is a switch in the dash to switch between 5 psi or 15 psi. (His and Her Switch, see pictures). Car will put you in your seat and keep you there. Car can be seen and has to be picked up in Auburn AL. You can send an inspector if you need. Car isn't a real SS.
      I have an appraisal for the car for $50,000 and a lot of receipts, catalogs etc. Also comes with the November issue of Chevy Magazine where it was featured.
      I purchased this Nova not long ago and it is the best muscle/classic pro touring I have ever owned. I had plans to keep her for a very long time but due to family and health events I have been forced to let her go and take care of other priorities. If you want more pictures please text me at 334-707-6273. Thanks!
      YOU CAN MESSAGE OR TEXT ME FOR PICTURES. THANKS
      Here are some Links and You Tube videos
      http://www.superchevy.com/features/1...ng-out-700-hp/
      http://www.scribd.com/doc/246085314/...nuary-2015-USA
      http://www.hotrod.com/events/car-cra...et-eliminator/
      http://www.hotrod.com/events/car-cra...mer-nationals/
      http://www.hotrod.com/events/car-cra...eliminator-ix/
      ▶ https://www.youtube.com/watch?v=xH06JHuTRcA
      ▶ https://www.youtube.com/watch?v=fgSXC_BTMxQ
      ▶ https://www.youtube.com/watch?v=uY26KEo24wk
