    Results 1 to 13 of 13
      Nov 2013
      Brisbane
      Country Flag: Australia
      Crazy spindle idea- will it work?
      I've got this crazy idea for making adapters of sorts that might allow me to use G8 front sindles and hubs in my conversion and I want to know if people in the know think its plausible or if I'm missing a key factor?
      Why do I want to use G8 spindles? I'm doing a conversion into a 68 Bird with A LOT of the gear out of a G8, including the IRS. Since the rear is wider, I'll be using high offset wheels and would like to keep the same offset and PCD for the front (rear is +56 offset, 5x120mm). I'm also going to use the brakes (calipers and rotors) from the G8, to match the rear brakes.
      Obviously spacers/wheel adapters are the easiest (and cheapest) option, but they are illegal in Australia.
      The next option is to have custom spindle hubs made that have the correct PCD and are longer, to account for the high offset. This still leaves me with having to make custom brake brackets.
      I'm a fan of the CPP AFX spindle, which would allow me to use the G8 hub assembly and then the wheel and brake rotor will bolt straight on. But this will again require a custom brake bracket AND a custom spacer (first pic) to gain the extra offset.
      The AFX spindle made me think that the original G8 spindle (second pic) already has the correct spacing and mounting for the rotors, wheels AND calipers, so how could I use that on the original Bird control arms? It would save me having large (and expensive) custom hubs, brackets and caliper mounts made and (like the AFX spindle), allows the use of new hub bearing packs. As a bonus, it would also allow for various wheel offsets and camber adjustment. The idea came from adjustable control arms, so something similar already exists and works, I'm just not sure if there's a reason that it doesn't exist for spindles themselves???
      So..........for the top mount, create a one inch steel block that has the same angled hole as the original top spindle hole. Then have a thick (hi tensile) steel threaded rod screwed into it at 90 degrees (pointing towards the G8 spindle). The other end of the rod is screwed into a threaded hole in the top mount of the G8 spindle. Both ends are locked in place by nuts (same as adjustable control arms). The bottom mount would be similar, except the G8 spindle end would be connected by a second steel block with a bolt through it. I've tried to draw it as best as I can in the third pic.
      Alternatively, if people thinks it's too dangerous to have the threaded rod, what about solid adaptors, like in the fourth drawing?
      AFX adapter for high offset wheels
      G8 spindle
      Adjustable adapter
      Fixed adapter
