      Jul 2011
      Hattiesburg, MS
      1978 Pontiac Trans Am $12k
      Bought the car almost a year ago so I could go on the Power Tour and Cruisin the Coast this year since I knew my Camaro project would not be ready. I missed out on the power tour but made it to cruisin the coast early this month. That has passed now I'm ready to get back on my Camaro project and could use the cash to get that project going. It is a good driver and I have repaired a lot to have it ready to cruise. Still a few things to be done but can be driven as is. Drives good and has AC. Original 6.6 liter with automatic transmission. Has dual flow master exhaust. Doesn't have t-tops but I picked up a t-top roof that I ran across and it will go with the car. If I ever had the car repainted I was going to put this roof on. Car is cameo white with carmine red interior.
      What's New:
      Brake booster
      Master cylinder
      Front brake hoses
      Front calipers and pads
      Accel plug wires
      Distributor rotor
      Valve cover gaskets
      Radiator
      AC kit including Compressor, condenser and lines.
      Carpet
      Floor mats
      Headliner
      Retrosound stereo
      Speakers 6x9 rear 4.5 in the doors
      Rear dash
      Rear arm rest panels
      All new Marshall Gauges including Tach, Speedo, oil pressure, temp, and fuel level. All work.
      Recent paint and decal kit
      New Boze snowflake wheels with nitto tires. 18x8 front and 18x10 rears. Cost $4000 for wheels and tires.
      Recently changed all fluids oil, coolant, rear end fluid, brake fluid.
      What it Needs:
      Paint was done right before I bought it. It wasn't the best job and I would call it a 20 footer. Door jams have overspray in them and look rough. Body work on doors could have been better. The roof,hood, fenders, trunk look good but the car could have looked a lot better with just a little more body work. The rear flares were painted on the car and are starting to crack along the seams. If I were to keep it I would repaint it but I'm pretty picky.
      Seats have tears in them and need to be recovered.
      The plastic pieces on the sides of the headliner could be replaced. They are there and I repainted them but they have cracks on them.
      Previous owner replaced all of the seals on the doors and trunk. He couldn't get the doors to close so he trimmed the seals with a razor blade. Soooooo they leak. I keep it in my shop so it doesn't get wet but def needs to be addressed if it will be outside.
      Car is located near Hattiesburg MS
      Asking $12,000 for it. I can email pics upon request.
      Mar 2010
      Alabama
      Please email pics to [email protected]
      I have a friend that is possible interested who also lives in mississippi.
      David Butler
      "If you're not first, you're last"
      67 Camaro Twin Turbo SBC (changing from Blow-thru to Holley HP EFI)
