    Results 1 to 9 of 9
    Thread: GXL OR TXL wire
      GXL OR TXL wire
      Is TXL wire the same as GXL w/a thinner insulation (polyethylene), or is one type better than the other, or does each type serve a specific purpose? I need to order a bunch of wire but not sure which one. Am I correct in thinking that the GXL is best for exterior areas, such as under the car, and that the TXL is better for interior and engine compartment?
      Dunwoody, GA
      GXL should be the better choice from what I know. we only use GXL on any and all major wiring jobs for cars. we make complete custom harnesses out of GXL. It is designed to stand up to oils and chemicals as well as weather.
      Trey
      ~ Jon Hammond
      That's what I needed to know. Thanks for the info..
      Nov 2004
      Colorado
      Quote Originally Posted by WS6
      Where do you get GXL wire? All the parts stores around sell the cheap stuff.
      I have had to buy complete harnesses from the boneyard to harvest the wire I need for my projects.
      Go to Terminal Supply.com.. They have it in bulk. Have read on this site that they're prices are good too.
      Dunwoody, GA
      haha terminal supply is who i use as well. they have a warehouse down here in Athens. you have to buy in pretty large quantity, but its very cheap that way. they have so much there its amazing. almost anything electrical you can think of really.
      Trey
      ~ Jon Hammond
      Gxl txl
      We work with GXL wire TXL wire and SXL wire, they all fallunder the same spec, the only difference is the jacket thickness, SXL is the thickest, GXL is thinner, and TXL is the most thin. we can seel this wire in colors, and with circuit identifications as well.
      M.D.
      Altek Systems Inc
      Southern Indiana
      TXL is what FORD and GM and Painless Wiring use
      Dec 2000
      NE Florida
      Txl gxl
      If you're doing ahrness repair / mods, or just some onesy-twosey type work, EFI connection has all the different factory (GM& Frod) color combos for the wiring & connectors, as sometimes the bigger places don't sell the it.
      http://www.eficonnection.com/eficonnection/wire.aspx
