    Results 1 to 10 of 10
      Nov 2014
      SI Alternator Charging Lite Blues
      I have a ’66 Buick that I am wiring up an SI alternator. I have wired this as I have successfully done before and I am getting an issue I have not seen before. I have wired it in similar fashion to this diagram (below) only I used the M & H Electrical Fabricators adaptor kit which basically plugs into the regulator harness and ‘neatly’ jumps the wires correctly. The kit also provide an adaptor which connects to the old style alternator lead and plugs into the SI alternator connector. I am confident that I have it wired correctly.
      The issue I have is that terminal 1 (one) from the alternator provides electrical current to the charging lite when the alternator is charging.
      Key Off / Engine Off – the charging lite has no power to either side (alt or ign) and lite is off
      Key On / Engine Off – the charging lite has ign on one side and grd on the other and the lite is on
      Key On / Engine On (assuming the alternator is charging) – the charging lite has ign on one side and charging signal on the other – the lite is off
      This is normal operation. The problem that I have is if I have key off / engine off (not running, no charging, the car is just sitting in the garage) then the charge lite is lit. If I disconnect the harness from the alternator, the lite goes out. If I test with the harness disconnected I have battery voltage at terminal #1 at the alternator. This is the terminal that connects directly to one side of the charge bulb. It is my understanding that this terminal should NOT have voltage until the alternator is charging. My parts supplier gave me another alternator and it tests the same.
      People have given me all kinds of solutions like I need a diode, or I need a resistor, etc. None of these people can tell me why they think I need these things except to say they have seen it online in some forum. Sending a voltage signal from this terminal on the alternator to the lite is correct so I believe that the wiring is correct – the issue is I don’t think I should have voltage until the alternator is charging. Any insight is appreciated.
