    Page 11 of 12 FirstFirst ... 6 7 8 9 10 11 12 LastLast
    Results 201 to 220 of 227
    Thread: FiTech Systems
    1. #201
      Jan 2013
      Abbotsford, B.C.
      The fuel pressure is internally set by fitech, non adjustable by our hands. I believe it determines the amount of pressure through its own programming. I read that it's set at 58psi out of the box.
    2. #202
      Just got my second unit a FiTech Mean street 800HP for my new Blueprint 496. The engine dynode at 601HP. Took me a few days to realized that the tach wire was not connected correctly. When I got that fixed runs great. I need to add more fuel on the startup. The idle is set at 1000, my return is very stiff as well. I will be looking at removing it, to see if it helps. FiTech is running good for me
      72 Baldwin Motion (Tribute) EFI
      67 SS 396 (496) Red EFI
      99 Hugger orange Z28 Sold
      2001 SS Camaro SLP 19K miles
    3. #203
      More of the install of the new 496
    4. #204
      May 2016
      Bay Area
      Quote Originally Posted by scott67ss396 View Post
      Very nice!!! Is your air cleaner sitting directly on the FiTech unit? Or are you using some type of gasket/crutch? My meanstreet is smaller than my K&N 12" air cleaner - I am using an 1" o-ring to fit the base of the air cleaner snuggly on the FiTech. It's not working too well as it moves with and off-centers my air cleaner. I would love to know what you're using! Thanks.
    5. #205
      Its from Jegs a Flat bottom, $43.00 works great
      JEGS Performance Products 50005
      Part Number: 555-50005
      Air Cleaner with Smooth Top 14" x 4"
      14" x 4"
      Made in the USA
      Includes:
      (1) 5-1/8" Centered Base
      (1) Polished Chrome-Plated Top
      (1) Reusable/Washable Cotton Element
      Fits:
      Edelbrock
      Carter
      Rochester
      Holley
    6. #206
    7. #207
      Jul 2015
      TORONTO
      My Kit is coming in Wednesday!!! Name:  2015-08-09 08.44.47.jpg
Size:  191.5 KBName:  30064_1med.jpg
    8. #208
      I almost got that kit, tells us how it works...nice ride
    9. #209
      Cornettsville, ky
      Only if you want to use a 6L80/90....not 4L60/80...
      hey Andrew idk if I ever responded to this or not earlier and im not trying to be a a-hole about it at all just wanted to clarify for people who do want to run a factory setup. the 4l60e was on 4.8 ls trucks in 2014. I haven't checked but im pretty sure vans still run the 4l variants. there is a conversion for the 6l trucks to retro the 4l kit I think it just is a harness and programing also but idk how cost effective it would be over a new harness.
    10. #210
      Sep 2009
      Atlanta,Ga.
      Can these be used with a Distributorless Ignition for BBC? Do they control timing?
      I am SUCH a rookie to Pro-Touring
    11. #211
      Jan 2013
      Abbotsford, B.C.
      Not sure about distributorless but it should work, and their GO EFI 4 and higher will control timing.
    12. #212
      Dec 2009
      Austin, Tx
      Yes, I'm running mine with HEI it uses the tach input
      https://www.pro-touring.com/threads/...0-Convertible)
      We all came into this world ignorant, it takes hard work to remain joyful in its bliss.
      --Hazewriter--
    13. #213
      Sep 2009
      Atlanta,Ga.
      Thank you all for that info. Now to figure out what coil on plug conversion kit to use.
    14. #214
      Jul 2015
      TORONTO
      I'm going to need to get a fuel pump now. I have. Rick's tank but need a FI pump
    15. #215
      Oct 2016
      Hello !
      6 months ago I've installed the meanstreet EFI system on a Edel performer rpm engine, about 400hp, it works really well but now I'm thinking about more hp and for the moment an engine swap is not really on my budget so I'm looking for a cheap method to add HP without modifying or swapping the engine.
      do you know if we can only replace the meanstreet internal MAP sensor by a 2.5 or 3 bar unit to make it compatible with turbocharger and add a MSD BTM or we are compelled to buy the power adder version ? I don't want to go above 600-650hp
      "The map sensor is integrated directly into the ECU so replacing it is not possible.
      You are not able to run any boost levels as the system has no idea how to tune for them." Fitech answer
    16. #216
      Good question, I may want to do that if I can.
    17. #217
      Oct 2016
      let us know if it works !
    18. #218
      Boonville, Missouri
      I'm with you on this as I want to pressurize my 416 with an old Mr. Norms Paxton. Nothing more than 6 psi. I thought long and hard on this and just purchase EFI 4 PA and just wont use all the features until I get ready to rebuild the engine again and drop the compression. I figure for the extra $100 I'll control fans or something with it.
      Tony Edler
      Illumin8s
      '73 Dodge Challenger
    19. #219
      Oct 2016
      I've still not decided what to do but If I buy the Fitech unit it will be the PA 1200hp cause I don't know if I will be compelled to run E85 or not, and with E85 we had to reduce the amount of HP that the system can support by 30% so 420hp with the Go EFI 600 won't be sufficient for a 600hp engine
    20. #220
      Apr 2016
      For those of you running the corvette style regulator with short return, do you just block off the return port on the FItech TB or is there another method? What would you use to block the return port? Thanks
