      Melbourne, FL
      Core support clearance ??
      Is there any sort of minimum clearance between the radiator and the core support ?? I'm getting ready to make some brackets to mount my radiator and was just curious.
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      Jun 2013
      Colon, Michigan
      Depending on how stiff your mounting cushions are, an 1/8 to 1/4" should be plenty of clearance between the radiator and any metal. I've seen quite a few cars at shows that will mount radiators without isolating them and always cringe. Will you be using an Aluminum Radiator? If so, another thing to watch for is to not make any grounding connections thru the radiator, which can also happen with contact of any surrounding sheet metal. This will create galvanic corrosion due to the coolant acting as an electrolyte. Here's a well written article on the effects of it.
      http://www.aluminiumdesign.net/desig...on-resistance/
      -Mike
      Melbourne, FL
      Just saw this. Thanks for the feedback. So insulating the radiator from the core support with the rubber cushions should prevent any grounding issues.
      Jun 2013
      Colon, Michigan
      Quote Originally Posted by 67 455 Bird ragtop View Post
      Correct. There was also an article in Hot Rod about 2 years ago covering an overheating issue and also commented on grounding issues through the radiator. If I come across it, I'll let you know.
      -Mike
