      Jun 2014
      The Woodlands, TX
      Innovate MTX-L AFR Gauge NIB
      The new Innovate Motorsports Digital MTX Series Air/Fuel Ratio Gauge utilizes the only 100% digital Wideband air/fuel ratio technology on the market! The award-winning patented DirectDigital™ technology we use is faster and more accurate than common “UEGO” gauges and is now more affordable! In addition, the gauge features a water resistant casing, interchangeable faceplates and bezels, and 2 fully programmable linear analog outputs for use with aftermarket engine managements systems and dataloggers!
      Patented DirectDigital™ wideband sensor control, the only 100% digital wideband air/fuel ratio technology!
      Digital display in AFR or Lambda
      52mm (2 1/6”) diameter gauge body
      Built-in Direct Digital™ Wideband Controller reduces wiring and simplifies installation
      Wideband O2 Sensor is compatible with all fuel types (Leaded, Unleaded, Diesel, Methanol, E85, etc)
      Ability to calibrate O2 sensor for increased accuracy
      (2) Configurable linear 0-5v analog output for wideband O² for use with piggy back or stand alone ECU’s as well as external data loggers
      Interchangeable faceplates and bezels: Black and silver bezel, black and white faceplates included
      Large digital readout and programmable “Digital Needle” provides the functionality of a needle style gauge with the pinpoint accuracy of a digital display
      Datalog using LogWorks on your PC
      Innovate MTS serial in/out (for use with other Innovate & 3rd party MTS enabled devices to add additional logging channels)
      $150.00 Shipped in USA
      PM me here or email me at [email protected] for details
      Jun 2014
      The Woodlands, TX
      Sold thank you parsonsj and Pro-touring.
