    Results 1 to 9 of 9
      Sep 2015
      What size hard lines
      Going to be running hard lines to my Engine from the cell. Cell has -8An Supply and return.
      Sould I run an 3/8 supply? where is the best place to get fittings also?
      Feb 2011
      dallas, tx
      use the stock 3/8 lines from engine to tank. Run a flexable hose off of the hardlines to the tank and another to the engine. On my build i actually laid out every fitting that i had to use.
      Sep 2015
      I have no factory lines to go off of. Il be creating everything that's needed. I was planning on running a flex line off the end to account for vibration
      1966 Mustang Coupe
      5.0 EFI- T5
      Feb 2011
      dallas, tx
      order the factory line off of www.firewheelclassics.com
      Sep 2015
      I have a 66 mustang. that link to go Camaros.
      Il just run and bend my own 3/8s line.
      1966 Mustang Coupe
      5.0 EFI- T5
      Sep 2015
      Rockvale TN
      Why not just run Russell push-lock hose the entire length and screw all the bending/flaring?
      Sep 2015
      Quote Originally Posted by HandOverFist View Post
      Hadnt seen those. That's a good idea! thanks!
      -8AN supply and -6AN return.
      1966 Mustang Coupe
      5.0 EFI- T5
      Sep 2015
      Rockvale TN
      Quote Originally Posted by rhurley View Post
      That's how I plumbed the '90 GT...
      Dec 2010
      Fredericksburg, VA.
      My MSD Atomic EFI kit came with Aeroquip AQP socketless hose. If you go to Summit Racing and do a brand search you can see all the AQP hose and fittings.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
